Pan and Tilt tracker
Ebo
Postby Ebo » Fri Nov 24, 2017 1:15 pm
Hi Im a mechatronics student in my final year. We have a project that tracks colour and outputs it to a pan and tilt device with the following specs
Brand LILIN
Model Code PIH-301
AC/ DC Type AC
Mount Type Top Mount
Max Load kg 38
Indoor/Outdoor External
Autopan Yes
Pan Speed o/ second 6
Tilt Speed o/ second 4
Swivel Angle o 350P, +30~ -40T
Pan Angle o 350
Housing Material Aluminium
Electrical Specifications Voltage: 24 VAC
Physical Specifications Weight kg: 7.5
Dimensions mm: 196 x 277
Environmental Specifications Operating Temperature oC: -20~+60
Protection: Weather Resistant
Model Info Can be integrated with Li-lin domes or matrix system by using the PIH-820 telemetry receiver, or the PIH-301C for hardwire control.
I was wondering if theres a way i can pulse a single to a relay at 5V and cause it to trigger a 24VAC pan and tilt device? IM using micropython to program the openmv cam. Reason for my asking is because i need to track colour in the open mv and send the according x and y coordinates somehow.. any help would be appreciated.
Sleep Engineering Student
Re: Pan and Tilt tracker
Postby kwagyeman » Sat Nov 25, 2017 11:03 am
Here's the relay driver circuit:
https://www.google.com/search?q=relay+d ... VeJBHRJRIM:
Please use the other thread you started.
