Controlling brushed motors with PWM
sergeyzwezdin
Contact:
Postby sergeyzwezdin » Tue Jul 18, 2017 7:59 am
Hello!
I'm trying to control brushed motor with OpenMV's PWM and getting wierd result.
Wiring scheme is following:
TB6612FNG dirvier used as a motor driver. There are two pins to define mode and another one for PWM. Mode pins connected to P8 and P9 OpenMV's pin. P7 pin connected to driver's PWM pin.
Test program is:
from pyb import Pin, Timer
m1_1 = Pin('P8', Pin.OUT_PP)
m1_2 = Pin('P9', Pin.OUT_PP)
m1_1.high()
m1_2.low()
m1_tm = Timer(4, freq=488.28)
m1_pwm = m1_tm.channel(1, m1_tm.PWM, pin=Pin.board.P7, pulse_width_percent=50)
With this code I getting this result: https://youtu.be/w19WEoutPcw
Why it moves intermittently? Same setup with arduino doing slow smooth moving (at exactly same hardware).
Any ideas?
Re: Controlling brushed motors with PWM
Postby kwagyeman » Tue Jul 18, 2017 12:27 pm
Ibrahim, can you help out on this?
Postby iabdalkader » Tue Jul 18, 2017 1:10 pm
Hi, yes I'll debug this and get back to you.
sergeyzwezdin
Contact:
Postby sergeyzwezdin » Wed Jul 19, 2017 2:33 am
Hi!
Any luck with it yet?
melofon
Postby melofon » Wed Jul 19, 2017 3:46 am
I would suggest using machine module in micropython - https://docs.micropython.org/en/latest/ ... l/pwm.html. Haven't had such experience yet, hope this thing works well with openMV. The plan is to test it maybe tomorrow (my robot is not ready yet).
Postby iabdalkader » Wed Jul 19, 2017 9:52 am
I tested your code with no changes (only added a loop after the code) it generates ~488MHz on pin P7 and P8 is high, and P9 is low:
I don't have a motor to test, but it seems the cam is doing exactly what you want.
sergeyzwezdin
Contact:
Postby sergeyzwezdin » Wed Jul 19, 2017 11:34 am
Yep, OpenMV works properly here. It seems problem with motor driver. I'll investigate it a bit more.
Thank you for your help and sorry for bothering.
sergeyzwezdin
Contact:
"machine.PWM" is not available on OpenMV, so no way to use it directly.
deshipu
Contact:
Postby deshipu » Thu Jul 27, 2017 5:11 pm
One possible difference is that Arduino UNO is 5V, whicle OpenMV is 3.3V — perhaps your motor driver expects 5V signal?
sergeyzwezdin
Contact:
Postby sergeyzwezdin » Fri Aug 11, 2017 1:55 am
In my case the root casus was broken driver.
