SPI slave problem
dsiganos
SPI slave problem
Postby dsiganos » Wed Dec 04, 2019 6:38 pm
Hi, trying to run the following script, renders the openmv H7 hardware unusable.
print('First line')
from pyb import SPI
spi = SPI(2, SPI.SLAVE, polarity=0)
ch = bytearray('ab')
res = spi.send_recv(ch, timeout=1)
print(res, ch)
When I try to run the script above, the hardware "appears" to hang.
I don't even see the first line printed.
The only way to get back to interacting with the board is to power cycle it.
If I remove the spi.send_recv call then the hardware does not freeze and the script runs to completion.
I have nothing connected to the SPI pins.
Any ideas?
Re: SPI slave problem
Postby kwagyeman » Wed Dec 04, 2019 7:29 pm
Yeah, what happens is that in slave mode the board needs to receive a clock from the SPI master. Without that clock the MCU will wait on the SPI receive call to return. The timeout should causes the system to throw an exception however if no clock was being received.
Um, I don't recommend using the OpenMV Cam as a SPI or I2C slave. I tried this long ago and determined it to be a bad path to go down and a waste of your time. Make it a master device.
The hanging part implies there's another bug however. Did you run this in the IDE? Does the USB disconnect after running the script?
dsiganos
Postby dsiganos » Wed Dec 04, 2019 7:44 pm
Yes, I run this from the IDE.
The IDE appears to hangs for 10-20 seconds and then eventually it comes back and shows the device as disconnected (I imagine something times out).
Postby kwagyeman » Wed Dec 04, 2019 8:00 pm
Yeah, that's the IDE timing out. Okay, there's probably a bug in the SLAVE mode. It should just throw an exception on board timeout. Instead it's getting stuck in an infinite loop.
Sorry about this... Whenever we update MP (like to version 1.11 with our latest firmware) various things break.
Postby iabdalkader » Thu Dec 05, 2019 6:00 am
Hi, there's an SPI example with the Arduino as the master device and the OpenMV Cam as the slave in Examples->00-Arduino/arduino_spi_slave.py that has been tested and know to work with the latest firmware.
