no file found
pcls1026
no file found
Postby pcls1026 » Fri Oct 25, 2019 10:58 am
It's been along time.
I just pulled up an old script. It has the following command.
img=image.Image("/blksqrclose.pgm",copy_to_fb=True)
When i run the script I get the following error.
os error: could not find file
The file is located at c:\user\jimkim\documents\blksqrclose.pgm
Any ideas?
Jim Sullivan
Re: no file found
Postby kwagyeman » Fri Oct 25, 2019 11:30 am
The script runs on the camera. You have to copy the image file to the camera. Make sure you have an SD card.
pcls1026
Re: no file found
Postby pcls1026 » Fri Oct 25, 2019 2:20 pm
I remember now.
Jim
pcls1026
Re: no file found
Postby pcls1026 » Fri Oct 25, 2019 2:44 pm
My image is grey scale 640x480. When I look at properties on the K drive it lists capacity at 81KB . The 307KB picture cannot be copied to the K drive.
Jim
Re: no file found
Postby kwagyeman » Fri Oct 25, 2019 5:46 pm
Please add an SD card. You can't save images on the internal flash.
pcls1026
Re: no file found
Postby pcls1026 » Sat Oct 26, 2019 1:02 pm
I have an SD card installed. How do I copy my image file to it?
Jim
Re: no file found
Postby iabdalkader » Sat Oct 26, 2019 1:23 pm
Jim
Use the PC to copy & paste and then umount and put the card in the camera, or put the card in the camera, connect to PC a driver will show up, copy & paste, unmount and reset the camera
pcls1026
Re: no file found
Postby pcls1026 » Sun Oct 27, 2019 6:16 pm
I followed your instructions:
" or put the card in the camera, connect to PC a driver will show up, copy & paste, unmount and reset the camera"
I put the card "sandisk ultra plus 16gb" in the camera with the red tab of the card facing the same way as the camera.
I plugged in the USB connection from the camera into a PC USB port.
In Windows Explorer the following showed up under "Computer"---Removable disk (K)
Disk(K) has one file named .openmv_disk.
Disk(K) has 80,000 bytes of space.
Is it possible the SD card is corrupted, or that the CAM7 software is corrupted. I'm running version 3.3.1
Jim
Re: no file found
Postby iabdalkader » Mon Oct 28, 2019 11:52 am
Make sure the card is formatted to FAT or exFAT (exFAT is faster) and please upgrade the firmware.
pcls1026
Re: no file found
Postby pcls1026 » Wed Oct 30, 2019 10:41 am
I reloaded the firmware.
I checked the K drive properties. It uses the FAT file system. It has 80 KBYTES of memory available. It ran its self-test successfully.
