Using the WiFi shield
deshipu
Contact:
Postby deshipu » Wed Sep 14, 2016 4:40 pm
I finally found some time to try the WiFi shield. I'm using the new IDE, and I upgraded the firmware with what shipped with it.
I have the shield connected, and I tried the "mjpeg_streamer" example, changing the SSID and KEY variables to match my local network.
The terminal displayed this:
MicroPython v1.8-4343-g33f9bbe on 2016-08-31; OPENMV2 with STM32F427
>>> Trying to connect... (may take a while)...
[-64, 2, 'swamp', 'f8:f0:05:f6:83:a5', '192.168.0.32']
Waiting for connections..
Connected to 144.49.0.16:0
The last line appeared when I entered "http://192.168.0.32:8080/" in the address bar of my chromium web browser, and hit enter. I got an error in the browser:
This site can’t be reached
http://192.168.0.32:8080/ is unreachable.
ERR_ADDRESS_UNREACHABLE
Curiously, the IP address of my desktop is "192.168.0.12", and not "144.49.0.16".
deshipu
Contact:
Re: Using the WiFi shield
Postby deshipu » Wed Sep 14, 2016 4:42 pm
I just tried again, and it worked this time. I wonder what happened.
Postby iabdalkader » Wed Sep 14, 2016 5:11 pm
deshipu wrote:I just tried again, and it worked this time. I wonder what happened.
I remember the default port in the example script was 8000, anyway, I made some major fixes to the WiFi driver and example script in v1.8 you should use that.. BTW it works great with MJpegViewer on Android, the url should look like this: http://ip:port
deshipu
Contact:
Postby deshipu » Wed Sep 14, 2016 10:18 pm
I wonder how hard it would be to have a remote REPL, similar to telnet?
Postby iabdalkader » Wed Sep 14, 2016 10:41 pm
deshipu wrote:I wonder how hard it would be to have a remote REPL, similar to telnet?
It's doable, but it will need some work, what you can do now easily is send scripts and execute them with exec.
