Baud rate
finnleh
Baud rate
Postby finnleh » Mon Jul 01, 2019 4:27 am
Hello! I have my arduino connected to the camera. They communicate through UART.
With a baud rate of 9600, the communication works just fine. But I need to increase the baud rate to 115200.
When I do that, the communication doesn’t work anymore. Is there a way, to change the baud rate for the camera? Or does it only work with 9600 baud rate?
Thank you for your help,
Finn
Re: Baud rate
Postby iabdalkader » Mon Jul 01, 2019 10:09 am
No it should work with any baud rate, do you also change the baud rate on the Arduino ?
finnleh
Re: Baud rate
Postby finnleh » Mon Jul 01, 2019 10:15 am
Yes, I did. In the setup, I set all baud Rates to 115200. Do i have to change it somewhere in the openmv code as well? Or does it do that automatically?
Re: Baud rate
Postby iabdalkader » Mon Jul 01, 2019 11:47 am
Yes you have to set the baud rate in the code:
uart = UART(3, 115200, timeout_char=1000)
