OpenMV Problem
finnleh
OpenMV Problem
Postby finnleh » Fri May 24, 2019 3:40 pm
Hello.
My camera has a problem: When I connect it to the laptop, it tries to connect, but just stops and blinks white the whole time. My laptop doesn't recognize the camera either. I didn't do anything to the camera, it just happened and then never fixed by itself. I can't do anything with the camera, because I can't connect it to ANY computer. It is not the cable either, because it works with the camera from my friends.
Do you know, what the issue could be, and how to fix it? Or do I need a new OpenMV...?
Finn
Re: OpenMV Problem
Postby iabdalkader » Fri May 24, 2019 4:23 pm
Have you tried re-flashing the firmware ? Tools->Run Bootloader
Re: OpenMV Problem
Postby kwagyeman » Sun May 26, 2019 12:16 pm
The white LED flashing is a hardware failure on the camera. If you can't fix this by going through the un-bricking prompts with OpenMV IDE then it could be a bad camera. We do test the cameras before they exit the factory so it's unlikely if it's one of our units (there are clones out there however).
