OSError when read BMP
ky66111
Postby ky66111 » Wed May 15, 2019 1:51 am
I generate some bmp image from cifar lmdb database using opencv. But when reading bmp, exception throws out: "OSError: Unexpected value read!"
import sensor, image, time
# Still need to init sensor
# Set sensor settings
sensor.set_contrast(1)
sensor.set_gainceiling(16)
# Set sensor pixel format
# Load image
img = image.Image("/viscifar/rgb.bmp")
# Add drawing code here.
# img.draw_line(...)
# Flush FB
sensor.flush()
# Add a small delay to allow the IDE to read the flushed image.
time.sleep(100)
Re: OSError when read BMP
Postby kwagyeman » Wed May 15, 2019 1:56 am
Hi, our BMP file reading code is extremely old and needs to be redone. I haven't had time for it yet however. Please generate the BMP file using GIMP and set the BMP file mode in GIMP to RGB565. You can select RGB565 under the advanced information tab.
