how to capture an image when an external trigger arised
Thiyagarajan
Postby Thiyagarajan » Sat May 11, 2019 5:21 am
Hi there,
As i'm newbie to openmv, I wanna know how to capture an image when an external trigger is given via gpio pin. I wanna capture an image when a buzor is pressed and find the qrcodes in that image and share those data via uart to a pc. I'm using openmv m7. Thanks in advance.
CODE:
import sensor, image, time
from pyb import *
i=0
def callback():
    i=1
ext = ExtInt(Pin('P7'), ExtInt.IRQ_RISING, Pin.PULL_DOWN, callback)
if(i==1):
   print('trigerred')
   img=sensor.snapshot()
   print('no signal')
this code doesn't works actually.
Re: how to capture an image when an external trigger arised
Postby iabdalkader » Sat May 11, 2019 9:07 am
from pyb import Pin, ExtInt
cap = 0
def callback (line):
    cap = 1
    if (cap == 1):
        img = image.snapshot()
        cap = 0
Thiyagarajan
Postby Thiyagarajan » Tue May 14, 2019 1:02 am
Thanks for your reply, Actually this is what the code which is in the example. I already tried this code, what happens when i run this code is exactly after 2000 frames the camera stops capturing. But the external interrupt on pin 7 doesn't capture any image. I want to capture when the 5V supply interrupts the pin p7 when pressing the buzor. I hope will get a perfect solution. Thanks in advance.
Postby iabdalkader » Tue May 14, 2019 5:11 am
I need to see your schematics and a picture of the setup.
Thiyagarajan
Postby Thiyagarajan » Thu May 16, 2019 2:49 am
Actually I gave +5V to pin Vin, -5V to gnd and then i gave +5V interrupt to pin p7.
Postby kwagyeman » Thu May 16, 2019 11:54 am
Um, can you also share the code or other details? I don't have an idea what's wrong still. You are putting 10V across the device power supply which is out of spec.
Postby iabdalkader » Thu May 16, 2019 2:08 pm
So is this issue fixed or not ?
Thiyagarajan
Postby Thiyagarajan » Thu May 23, 2019 2:23 am
Actually, I have shared the code already i think. Is there anything wrong with my power supply.? lemme have a suggestion for external interrupt supply. I have tried connecting -5V to gnd and +5V interrupt to pin p7 also.
Thiyagarajan
Postby Thiyagarajan » Thu May 23, 2019 2:24 am
Not, yet fixed abdal.
Postby kwagyeman » Thu May 23, 2019 2:32 am
Hi, +5v to the pin and -5v to gnd is 10V across the camera's I/O pin. That will destroy the camera. Can you post a schematic of what you are doing?
openmvdev
Postby openmvdev » Tue Jun 04, 2019 7:06 pm
I am having the same issue. Connected via USB to windows 10.
Locks up after about 2 seconds
my code
cap = 0
    cap = 1
ext = ExtInt(Pin('P5'), ExtInt.IRQ_RISING, Pin.PULL_DOWN, callback)
ext.enable()
#uart = pyb.UART(3, 115200, timeout_char = 1000)
    if (cap == 1):
        #img = sensor.snapshot()
        #img = img.compressed(quality=35)
        #uart.write(img)
        print("cap_found")
        cap = 0
Postby kwagyeman » Tue Jun 04, 2019 7:55 pm
Can you repost your code with code tags? Also, I notice you are not using global in your callback method. Python methods do not have scope of variables like C unless you say a variable is global before hand.
    cap = 1
Is not valid python code. You have to do:
    global cap
    cap = 1
openmvdev
Postby openmvdev » Tue Jun 04, 2019 11:08 pm
Thank you for the suggestion. Unfortunately it still did not work. No at big issue at this time, I decided to trigger via a serial port command.
Users browsing this forum: Bing [Bot] and 0 guests
