Using the Portenta's IMU with Micropython code
Place for technical questions related to the Arduino Portenta H7.
idohalamit
Postby idohalamit » Fri Jan 08, 2021 6:44 am
How can I use the Portenta H7 IMU inside my Micropython code?
Re: Using the Portenta's IMU with Micropython code
Postby iabdalkader » Fri Jan 08, 2021 10:05 am
The Portenta H7 doesn't have any IMUs as far as I know.
rocksetta
Contact:
Postby rocksetta » Sat Jan 09, 2021 10:25 pm
I was thinking of getting the adafruit lsm9ds1 https://learn.adafruit.com/adafruit-lsm ... f-breakout as it should work with the same code as the accelerometer examples for the Nano33BleSense. Anyone know if this accelerometer works with the PortentaH7?
EDIT: Sorry I edited your post instead of replying :shock:
40 years coding,
B.Sc. Chemistry, B.Ed, Dp. Consl
Teach: #Robotics, #Coding
Edge Impulse Ambassador
Postby kwagyeman » Sat Jan 09, 2021 10:49 pm
We got something you will like coming soon :)
idohalamit
Postby idohalamit » Sun Jan 10, 2021 9:36 am
Can you recommend any IMU I should order to use with Micropython? I need to order ASAP
Postby kwagyeman » Sun Jan 10, 2021 11:42 am
idohalamit
Postby idohalamit » Sun Jan 10, 2021 2:41 pm
Exactly! Thanks a thousand
Postby iabdalkader » Sun Jan 10, 2021 10:18 pm
There's no reason why it shouldn't, you can use this module I used for the Nano33 and the Nano33's example:
https://github.com/hoihu/projects/blob/ ... lsm9ds1.py
Return to “Arduino Portenta H7”
