OpenMV as Autoguider for astrophotography?
frank26080115
Postby frank26080115 » Tue Jul 28, 2020 3:21 am
You guys seem to be the perfect hardware for a headless astrophotography autoguider
Background: the Earth spins, so the stars in the sky are always moving. If you want to take a photo of something really dark and far away in the night sky, you need to do long-exposure photos but since the stars are moving, you need to move the camera in the opposite direction of the Earth. You can buy a star tracker for this but some star trackers allow you to add a optional secondary camera, an autoguider camera, to move more accurately, you get a sharper image.
Problem being they are $150 for just the camera, plus another $50 for the guide scope, plus you need a laptop to run the software.
I'm playing around with the idea of making all of this cheaper, or at least get rid of the laptop.
Anyways, the algorithm should be very simple. Find a dot, follow the dot by giving the star tracker (or EQ mount) one of four basic signals: left, right, up, down. (it's controlled via a ST4 cable, just 4 signals, active low, very simple)
Usually during the initial setup, it'll do a calibration. It locks onto a dot, tells the tracker/mount to go left for a few milliseconds, and see how much it moved and in what direction. This should be easy too.
My options are:
* smartphone with a telephoto lens and a Bluetooth nRF51 doing the ST4 signalling (it sounds cheap but I'd rather still have my phone in my hand all night)
* raspberry pi and HQ camera and a CS telephoto lens (price getting expensive)
* ESP32 cam (where do I get lenses for these? The camera's quality is usually terrible, dead pixels and such. Plus, I'm not excited about writing image processing in C++)
OpenMV hits a good price, has the super telephoto lens, runs image processing, has GPIOs. Optionally I can add the LCD shield or the Bluetooth shield.
Now I have no idea what the OpenMV camera would actually see when it's pointed at a star. This is why I'm here on this forum.
My next bit of research revealed that OpenMV is limited to 0.5s of exposure. This should be OK, I think... my 350mm camera lens would see star trails at 2.5s. 0.5s should be fine if I point it at a super bright star like Vega.
The max gain is 32. No idea what that looks like in terms of brightness and noise. I'm honestly not sure how to convert gain to ISO, I know "base ISO" is supposed to be gain of 1, right?
I'm guessing the super telephoto lens is fixed focus at infinity? As long as the star looks round, my idea should work, I just need a point or circle detector algorithm.
Can somebody with the super telephoto lens take a couple of photos of the night sky to share with us? Extra points if you can run the circle detector and provide a plot of XY position frame-to-frame so we can get an idea of the motion noise. (don't worry, we can filter this noise out, the earth doesn't change speed)
Has anybody experimented with adding a heat spreader to the bottom of the OpenMV camera sensor PCB?
Thanks, hope you all had a chance to see Comet NEOWISE
Re: OpenMV as Autoguider for astrophotography?
Postby kwagyeman » Tue Jul 28, 2020 10:18 am
Hi, you're going to need to buy the camera to get the answer to most of these questions.
Anyway, you can make the max exposure longer than 0.5 seconds. If you turn the PLL on the camera off and do other ticks you can make it very long since we give you direct hardware control of the system. E.g. slow the clock way down, etc.
As for the camera to use, the global shutter module will give you the most precise picture. However, it's expensive. The default camera is cheap and has large pixels for good low light response. So, it will probably do the job too.
Tracking the stars can be done with find_blobs().
frank26080115
Postby frank26080115 » Tue Jul 28, 2020 4:57 pm
Hi thanks for the info so far. I ordered the plus version just now.
Calculations tells me that it'll be a pretty crappy guider, 11.6 arc sec per pixel. I might end up turning this into a polar alignment camera instead. Gonna need to write a fake plate solver.
Testing is going to be a pain lol a few nights ago a firetruck showed up to kick away all the photographers and astronomers from a spot on Skyline.
frank26080115
Postby frank26080115 » Wed Jul 29, 2020 5:55 am
hey I just read about
The OpenMV Cam has two memory areas for images. The classical stack/heap area used for normal MicroPython processing can store small images within it’s heap. However, the MicroPython heap is only about ~100 KB which is not enough to store larger images. So, your OpenMV Cam has a secondary frame buffer memory area that stores images taken by sensor.snapshot(). Images are stored on the bottom of this memory area. Any memory that’s left over is then available for use by the frame buffer stack which your OpenMV Cam’s firmware uses to hold large temporary data structures for image processing algorithms.
If you need room to hold multiple frames you may “steal” frame buffer space by calling sensor.alloc_extra_fb().
If sensor.set_auto_rotation() is enabled this method will return a new already rotated image object.
Note: sensor.snapshot() may apply cropping parameters to fit the snapshot in the available frame buffer space given the pixformat and framesize. The cropping parameters will be applied to maintain the aspect ratio and will stay until sensor.set_framesize() or sensor.set_windowing() are called.
The H7 Plus has enough RAM to perform find_blobs() on the full 5MP resolution image, right? I don't need high frame rate.
Postby kwagyeman » Wed Jul 29, 2020 10:30 am
Yep! It will be super slow. But, no problem.
frank26080115
Postby frank26080115 » Wed Jul 29, 2020 3:35 pm
I guess I'll find out how slow when it gets here
My plan is to sort the blobs by brightness. It looks like I can get a list of blobs easily. My next questions:
Is there a limit on the number of blobs detected? There could be... ahem... a lot of stars.
If a blob’s bounding box area is less than area_threshold it is filtered out.
If a blob’s pixel count is less than pixel_threshold it is filtered out.
I need the exact opposite of that. I need to keep small blobs but remove big blobs. I am guessing that I have to use threshold_cb? Or do I feed it a negative number or something? (this isn't very important, a big blob would mean I need to retry the capture anyways)
I see I can get a circle representing each blob. What's the best way to determine the "brightness of a star"? I think I see a b_and() function that accepts a circular mask, and I can probably call get_histogram() to get the statistics, but that sounds like it'd operate on an entire 5MP image, whereas I only need to sum up like maybe 10 pixels. Would you suggest I just iterate over the rectangular bounding box with get_pixel() instead?
Is there a more lightweight call for get_histogram if I only need min and max? Would it be faster if I iterated over the entire image myself? Honestly I just want a function that tells me if I have at least one true white pixel and one true black pixel.
Postby kwagyeman » Wed Jul 29, 2020 5:39 pm
Hi, just let find_blobs() run with no area/pixel thresholds and it will return all the blobs.
The callback method is useful however to stop before a blob is added to the output list and execute functions on that blob. You can target the ROI of get_histogram to lie on the blob and then filter the blob out by it's brightness.
E.g. get_histogram(roi=blob.rect())
frank26080115
Postby frank26080115 » Thu Jul 30, 2020 5:05 am
Do you guys have any specs on the optical errors of the lens and the soldering planarity of the sensor? I need he view to be perfectly parallel with the scope holder, or find a way to calibrate away that error. So I want to know how straight the lens is and how level the soldering is on the sensor.
Pretty sure polar scopes are usually machined aluminum. Commercially available polar alignment cameras and autoguide cameras all look like machined aluminum.
Guide scopes don't really care about the parallelism since there must be a calibration routine anyways. I'm ignoring this use case for now.
I don't own a lathe. I have my own FDM 3D printer and at work we have a Form 2. My current plan is to just do as good of a job as possible and then run a timelapse capture session overnight, calibrate based on the centroid of the circles captured.
Plan B is to just swap with an already aligned polar scope, and see what the difference is. But just touching the whole setup after alignment is risky. This will need to be done during the day with a stationary object on Earth, not a star, so maybe I can just bolt the scope holder to something that's sturdier than a 3 legged tripod.
Postby kwagyeman » Thu Jul 30, 2020 10:24 am
Haha, no.
There's a reason the camera is cheap... Because it's not calibrated. At all :). We could add two 0s. To the price for all of that if you want.
frank26080115
Postby frank26080115 » Mon Aug 03, 2020 4:31 am
I envisioned that the WiFi shield provide a preview of the image to a smartphone. It's gotta be full resolution for the exposure check. The actual plate solving bit can be just SVGs.
I am wondering if there are performance penalties. I am considering using a ESP8266 as a co-processor just to be the HTTP server if the performance penalities for the ATWINC1500 is too high.
Very simply... is the ATWINC1500 driver completely triggered by interrupts? Or is there a periodic SPI poll?
I'm sure you optimized the crap out of everything for your race cars but just wanna make sure.
Postby kwagyeman » Mon Aug 03, 2020 11:39 am
Hi, the ATWINC1500 used to be bad. But, when doing the interface library updates for it I fixed a lot of issues with it. It works using 40 MHz SPI. Transmit is very fast and doesn't block. RX works but is not as performant. The WINC1500 cannot actually handle a large packet stream input from another device over WiFi without falling over itself. Generally, what happens is that for UDP messages are dropped. TCP works better for RX since the WINC1500 can slow the external device down. Transmit can do 15 Mb/s if you were just moving a large pre-allocated array. However, you should get about 7.5 Mb/s in practice on average.
Anyway, use TCP to do transmit. You should get above 5 Mb/s easily.
Postby kwagyeman » Mon Aug 03, 2020 11:43 am
Working on it. At the start of this year a lot of things weren't. Right now... SDRAM is as fast as it can be. And we've got the camera DCMI driver working as fast as it can. We will be adding double buffering soon to finish maximizing the performance out on that. Regarding I/O. When I made the interface library we fixed all issues with SPI/I2C/CAN/UART to get the best speeds out of these interfaces and verified that the bandwidth is maxed out with a logic probe.
SD Bandwidth needs to be worked on still (will do after double buffering is enabled).
