Using the I2C protocol
deshipu
Contact:
Postby deshipu » Fri Feb 12, 2016 3:32 pm
I finally have some more time for experimenting with OpenMV. Since I want it to control a hexapod robot, that's a lot of servos to take care of. So I built myself a simple servo controller based on a Pro Mini, with which I can communicate over I²C, basically just sending the servo positions to the registers. I have tested it with Raspberry Pi and PyBoard, and it all works perfectly fine there.
Today I tried connecting it to OpenMV. Here are my results:
  • First of all, the labels at https://openmv.io/docs/openmv/quickref.html are wrong -- the SDA and SCL are swapped. SCL is PB11 and SDA is PB10.
  • Scanning initially works. Just after connecting the OpenMV board and initializing the I2C class, I can do scan() and it shows my device.
  • Writing to the device doesn't seem to do anything (at least my device doesn't receive correct data).
  • As soon as I try writing, either with send() or mem_write(), scan() only returns an empty list, and any further writes result in OSError: 16.
  • That continues through soft-reset (ctrl+d) and reset of my device. Only switching the OpenMV off and on again resets it to the initial state.
Below is an example session demonstrating what I mean:
>>> import pyb
>>> import ustruct
>>> bus = pyb.I2C(2, pyb.I2C.MASTER)
>>> bus.scan()
[9]
>>> bus.mem_write(ustruct.pack("<H", 1500), 9, 0)
>>> bus.scan()
  File "<stdin>", line 1, in <module>
OSError: 16
Micro Python v1.4.4-125-g07c8f99 on 2015-08-18; OPENMV2 with STM32F427
>>> import pyb
>>> bus.scan()
Am I doing something wrong? Is there anything I should try?
deshipu
Contact:
Re: Using the I2C protocol
Postby deshipu » Fri Feb 12, 2016 3:43 pm
I just checked with a pocket osciloscope, and after doing the read/write the SCL line stays permanently pulled down on the side of OpenMV.
deshipu
Contact:
Postby deshipu » Fri Feb 12, 2016 5:59 pm
deshipu
Contact:
Postby deshipu » Fri Feb 12, 2016 6:12 pm
The following makes it work properly:
>>> import pyb
>>> import ustruct as struct
>>> bus = pyb.I2C(2, 0)
>>> bus.scan()
[9]
>>> pyb.disable_irq(); bus.mem_write(struct.pack("<H", 1500), 9, 0)
True
PYB: enabling IRQs
Postby iabdalkader » Fri Feb 12, 2016 8:54 pm
You know the camera doesn't have pull-ups right ?
Postby iabdalkader » Fri Feb 12, 2016 9:08 pm
deshipu wrote:Perhaps this is related? https://github.com/micropython/micropython/issues/1765
It is related, but it seems you're getting an error first that triggers the DMA issue. When IRQs are disabled, I2C doesn't use DMA.
I'll apply that patch, thanks!
Postby kwagyeman » Sat Feb 13, 2016 8:45 am
Docs should be updated now. Thanks!
(Sorry about this all being in a bad state right now. It will get much better soon).
deshipu
Contact:
Postby deshipu » Sat Feb 13, 2016 8:52 am
I know this is pretty much beta, and I don't expect everything to work out of the box. I'm experimenting with this because it's fun (at least when you don't do it as a job) and I hope it's helpful. Thanks for your hard work!
Postby kwagyeman » Sat Feb 13, 2016 9:07 am
If you want to bit bang the I2C... see this file for how to drive the lines perfectly:
https://github.com/openmv/openmv/blob/m ... soft_i2c.c
Funny, but, we should just have python wrappers so you can call that code.
deshipu
Contact:
Postby deshipu » Sat Feb 13, 2016 9:59 am
Yes, I noticed that you use that in the mlx python module. Is that because you also had problems with I2C?
By the way, that code also has the SDA and SCL pins swapped, I think?
Postby kwagyeman » Sat Feb 13, 2016 11:06 am
No, When Ibrahim did the initial development he didn't use the PYB module. As for the MLX code. That is all working now and has been tested.
I fixed the swap info in the docs.
stealthmedal
Postby stealthmedal » Sun Jul 17, 2016 5:58 pm
It seems that this issue still persists with these functions. Is there a work around for the OSError 16 problem?
Postby kwagyeman » Sun Jul 17, 2016 6:29 pm
Are you using the correct i2c bus? I tested out the i2c functions with an eeprom and they worked.
I won't have acess to a desktop PC until later this week so this is about the best I can help.
stealthmedal
Postby stealthmedal » Sun Jul 17, 2016 7:13 pm
I am using bus #2. I would like to use the openMV cam as a master to an arduino uno using the slave sketch here: https://www.arduino.cc/en/Tutorial/MasterWriter
I was able to send a few bytes of data, but after some time, the cam gives the OSError 16. I'm not entirely sure what I am doing incorrectly.
Postby kwagyeman » Mon Jul 18, 2016 12:08 pm
Ibrahim will have to take a look at this. It's highly likely there's a firmware bug for this. And... if there's a bug a firmware fix can be put out very quickly.
Postby iabdalkader » Mon Jul 18, 2016 3:08 pm
I think the STHAL I2C driver needs a patch, will look into it and get back to you.
Postby iabdalkader » Fri Jul 22, 2016 8:25 am
I already applied the I2C patch a while ago, make sure you have the latest firmware.
https://github.com/openmv/openmv/commit ... cc378b3f4b
Postby iabdalkader » Fri Jul 22, 2016 8:38 am
deshipu wrote:Yes, I noticed that you use that in the mlx python module. Is that because you also had problems with I2C?
We're using soft_i2c for MLX because it's more flexible, it allows you to control the STOP condition after a read/write, the sthal I2C driver on the other hand always generates a STOP after a read/write.
deshipu
Contact:
Postby deshipu » Mon Aug 15, 2016 2:50 pm
Thanks, that makes sense.
