What is the best way to check memory usage?
GregR
Postby GregR » Sat Sep 30, 2017 11:13 pm
I have a project that has about 500 lines of code and one class in an external .py file. I am getting memory errors when I try to start the project.
print('Used: ' + str(gc.mem_alloc()) + ' Free: ' + str(gc.mem_free()))
Claims that I have about 23K free yet the errors I get complain about memory allocation failed for hundreds of bytes.
The code that pushes the project over the edge doesn't involve any large memory allocations. I can light switch the problem by adding and removing a dozen lines of basic code.
What is the best way to troubleshoot problems like this?
Regards,
Greg
Re: What is the best way to check memory usage?
Postby kwagyeman » Sat Sep 30, 2017 11:19 pm
Can you post the code that's the issue? Python hides a lot of memory alloc sometimes. Usually, heap fragmentation is a problem if you allocate large things and remove them repeatedly.
GregR
Postby GregR » Sat Sep 30, 2017 11:29 pm
Hi Kwagyeman,
I can't post all of it as it's for a client. I'm using the OpenMV as rapid proto tool...
I have the project working in pieces and didn't hit the problem till I tried to combine the parts.
The interesting thing is that I'm using some dotstar LEDs from adafruit for the illumination.
I was able to lightswitch the problem by just adding or removing a block like:
dotStarWhite = [0xFF,0x0F,0x0F,0x0A,\
                0xFF,0x0F,0x0F,0x0A]
illuminatorWhite = dotStarPrefix
illuminatorWhite += bytes(dotStarWhite)
illuminatorWhite += dotStarSuffix
Regards,
Greg
Postby kwagyeman » Sun Oct 01, 2017 12:28 am
From my knowledge of MicroPython that array is actually 4X larger than you think since each number is stored in 4 bytes. Then, MP will allocate a new array on the += and another new array on the += again. Your script takes space too in RAM when it's parsed into a byte array.
This seems to work on my M7:
import gc
dotStarPrefix = [0xFF,0x0F,0x0F,0x0A,\
illuminatorWhite += dotStarPrefix
print(illuminatorWhite[0])
It prints:
Used: 3072 Free: 52816
Used: 3440 Free: 52448
Used: 3792 Free: 52096
Used: 4000 Free: 51888
Used: 4432 Free: 51456
Used: 4928 Free: 50960
255
Used: 5120 Free: 50768
GregR
Postby GregR » Mon Oct 02, 2017 3:27 pm
That is interesting and certainly good to know about the 4x.
The part I didn't explain very well is that adding or removing that block of code can light switch the problem.
Based on your experiment we are talking about roughly 2k.
Claims that I still have around 20k available.
Any suggestions for further troubleshooting this?
Regards,
Greg
Postby kwagyeman » Mon Oct 02, 2017 7:03 pm
Mmm, since I can't see the code it's kinda hard. Can you make some code that shows the error that I can try? I can debug then.
One thing to also try is to preallocate. I.e. allocate a bunch of large things first, then, deallocate one, put a new thing in it's place, and keep going. The heap may be fragmented where it can't find a large chunk free. I guess we should add a call to MP that returns the max free block size available.
By allocating your large items first you free prevent space they use from being fragmented.
Postby iabdalkader » Wed Oct 04, 2017 7:53 pm
Hi, yes use this to dump GC alloc table:
machine.info(1)
Dots are free blocks, anything else is an allocated GC block. Note 1 GC block == 16 bytes.
