M7 Bricked
cagiva
M7 Bricked
Postby cagiva » Mon Sep 11, 2017 10:44 pm
My M7 module seems to be bricked. I've followed the IDE instructions, but it still doesn't work. It just doesn't enumerate anymore. The LED keeps just flahsing after the LED turned green. Can someone please send me the instructions on how to resolve this on a Mac OSX 10.10.5? TIA!
Screen Shot 2017-09-11 at 7.46.40 PM.png (52.98 KiB) Viewed 5093 times
Screen Shot 2017-09-11 at 7.40.28 PM.png (56.8 KiB) Viewed 5093 times
Screen Shot 2017-09-11 at 7.40.02 PM.png (81.18 KiB) Viewed 5093 times
Re: M7 Bricked
Postby kwagyeman » Mon Sep 11, 2017 11:13 pm
What color does the LED flash? Also, please remove any USD that's inserted when updating it. Let me know, thanks.
cagiva
Re: M7 Bricked
Postby cagiva » Mon Sep 11, 2017 11:59 pm
The LED is flashing rapidly and it looks like a white color. There is not USD inserted. Thanks.
Re: M7 Bricked
Postby kwagyeman » Tue Sep 12, 2017 1:05 am
Oh, the white LED flashing is a hardware error. Um, can you try loading the DFU image instead of the bin image?
The openmv.dfu file? Note that you need to have all the dependencies installed for the pydfu.py script to run on your Mac.
cagiva
Re: M7 Bricked
Postby cagiva » Tue Sep 12, 2017 1:19 am
Uploaded the openmv.dfu file, but the LED still flashes white after the reprogramming dialog completed.
I'm pretty much experiencing the same problem/behavior described here:
viewtopic.php?f=6&t=208#p1144
When you wrote, "DFU is painfully slow." How slow? 5 mins, 1 hour, a day?
Re: M7 Bricked
Postby kwagyeman » Tue Sep 12, 2017 1:37 am
DFU takes 5 minutes.
Is this a new OpenMV Cam M7? Also, can you check what the error log.txt file on the camera says? Does the uPy flash drive show up when you connect it to the PC?
cagiva
Re: M7 Bricked
Postby cagiva » Tue Sep 12, 2017 11:51 am
It was pre-ordered back on December 15 directly through your website (purchased by guy.power@nasa.gov) so it's probably one the first boards shipped out.
It's been stored in our lab until now when we decided to use it for one of our projects.
How can access the log.txt file on the camera when it doesn't show as an external driver anymore?
How can see the uPy flash drive on a mac?
Re: M7 Bricked
Postby kwagyeman » Tue Sep 12, 2017 12:43 pm
Mmm, okay, can you try to find a Windows PC and run the DFU bootloader on that? The USB flash drive failing to appear means that the firmware image is basically dead. However, the camera should be unbrickable with DFU. I'm thinking there may be a problem with pydfu on Mac.
cagiva
Re: M7 Bricked
Postby cagiva » Wed Sep 13, 2017 8:28 pm
I used a Windows 10 machine as you suggested, but the LED still continues flashing white after running the Bootloader from the IDE and it completes.
Re: M7 Bricked
Postby kwagyeman » Wed Sep 13, 2017 9:12 pm
Okay, send me an email for a replacement.
cagiva
Re: M7 Bricked
Postby cagiva » Wed Sep 13, 2017 10:50 pm
I just sent you email to openmv@openmv.io
Thank you for offering a replacement.
