This is to report an unexpected result when trying to use cpufreq.set_frequency() on two different H7 boards.I want to set the CPU frequency as low as possible to reduce power consumption. I tried this:
cpufreq.set_frequency(50)
which worked fine on some boards. But when I got a new batch this instruction throws an error (unsupported frequency or similar). Looks like the new boards support 60MHz but not 50MHz. The documentation for cpufreq.get_supported_frequencies() says this:
“Returns the supported CPU frequencies… [60/50, 120/100, 240/200, 480/400] on the OpenMV Cam H7 Rev V/XY silicon in MHz.”
If I look at the chips I see the older chip has “Y” and the new chips say “V”. I ended up doing dealing with the issue like this:
print("Setting CPU frequency to the lowest of these:")
supported_frequencies = cpufreq.get_supported_frequencies()
for freq in supported_frequencies:
print(str(freq) + "MHz")
# Set the lowest supported value
cpufreq.set_frequency(supported_frequencies[0])
New chips give this output:
60MHz
120MHz
240MHz
480MHz
old chips say this:
50MHz
100MHz
200MHz
400MHz
It might be useful to expand the documentation in this area…
In both cases I am using the “latest” firmware (“MicroPython: v1.13-r22 OpenMV: v3.8.0 HAL: v1.9.0 BOARD: OPENMV4-STM32H743”)
