Defect Pixel Correction
Postby kwagyeman » Tue Sep 01, 2020 7:20 pm
This got solved in an email thread... so, posting the results here:
# DEFECT PIXEL CORRECTION FOR GLOBAL SHUTTER MODULE
import sensor, image, time
def defect_pixel_correction(img, point_list):
    Input is an image object 'img' and a list of points [(x,y),(x,y),etc.]
    for p in point_list:
        val_list = []
        for i in range(3):
            for j in range(3):
                val = img.get_pixel(p[0]+i-1, p[1]+j-1)
                val_list.append(val)
        val_list.sort()
        # median
        try: # for the case that this pixel is on the image border
            img.set_pixel(p[0], p[1], val_list[4])
        except:
def defect_pixel_correction_2(img, point_list):
    # instead of median the value of one neighbor pixel is copied
            img.set_pixel(p[0], p[1], img.get_pixel(p[0]+1, p[1]))
        except:
def find_defect_pixels():
    # if you use this, you have to cover the lens before starting this code
    thresh = 20
    ind = []
    for posx in range(sensor.width()):
        for posy in range(sensor.height()):
            if img.get_pixel(posx, posy) > thresh:
                ind.append((posx, posy))
    return ind
sensor.set_framesize(sensor.WVGA2)   # Set frame size to QVGA (320x240)
correction = 2     # 0 = no correction
                   # 1 = median correction (lens must be covered at the beginning)
                   #     recommended for low resolution (e.g. QQVGA)
                   # 2 = copy one neighbor pixel (lens must be covered at the beginning)
                   #     recommended for high resolution (e.g. WVGA2)
if correction > 0:
    ind = find_defect_pixels()
    clock.tick()                    # Update the FPS clock.
    if correction == 1:
        defect_pixel_correction(img, ind)
    elif correction == 2:
        defect_pixel_correction_2(img, ind)
    print(clock.fps())              # Note: OpenMV Cam runs about half as fast when connected
