image distortion
oramafanis
image distortion
Postby oramafanis » Fri Aug 07, 2020 3:31 am
Hi there,
i have a strange problem with the images from an openmv h7 with global shutter module attached.
no matter what lens i will use always the distortion in the image is bigger from the left side that the right.
Is this a hardware fault?
I have tested all the lens ir telephoto and the lens that come with the global shutter module.
the camera is perfectly leveled to the surface of the inspection.
please hve a look on the image below i have took with the standart global shutter module:
it looks like the sensor isnt allign well on the board?
Re: image distortion
Postby kwagyeman » Fri Aug 07, 2020 1:32 pm
We don't make any promises on how perfect the alignment of the sensor is.
But, what's the error exactly? Can you point out the issue in the image below?
mirkwood
Postby mirkwood » Sat Aug 08, 2020 1:40 am
If your lens is not directly over the top of the sensor it will do this.
I don't think you can physically change the alignment but you can use image.lens_corr with the x_off and y_off set to correct it (this is assuming it's just a x/y lens displacement).
Although the difference is so huge in your image I wonder if the lens and sensor are at an angle to each other? Is it cross threaded?
Postby kwagyeman » Sat Aug 08, 2020 11:19 am
Hi, just move the lens housing. It's probably not aligned via that. So, unscrew the two black acres on the back and adjust those to get it straightened.
oramafanis
Postby oramafanis » Sat Aug 08, 2020 2:59 pm
Ok then I will give it a try
