I am trying to save image in sensor.BINARY format but image.binary saves in sensor.GRAYSCALE format.
I have used example,
color_binaqry_filter_1.py
Color Binary Filter Example
This script shows off the binary image filter. You may pass binary any
number of thresholds to segment the image by.
import sensor, image, time
sensor.set_pixformat(sensor.GRAYSCALE) # USING GLOBAL SHUTTER CAMERA → changed from sensor.RGB565
# Test red threshold
for i in range(100):
img.binary([red_threshold])
print(img)
> OUTPUT: {"w":320, "h":240, "type"="grayscale", "size":76800}
Because of this problem, I cannot save image.binary() into extra frame buffer pre-defined as "sensor.BINARY".
I was expecting it would automatically convert image to binary format after image.binary().
Without looping through image and assigning pixel-by-pixel into frame buffer, is there a simple method doing this?
I tried to look for examples but there is no conversion examples for binary image.
I look forward to your reply,
Kind Regards
Phil
