blob region
oramafanis
blob region
Postby oramafanis » Mon Aug 03, 2020 7:49 am
Hi there,
i was wondering if it is possible to use an area of a blob as region of another blob.
I don't mean the rectangle that outputs but the exact area of a blob so to find blobs of other color inside it.
Re: blob region
Postby kwagyeman » Mon Aug 03, 2020 11:33 am
Hi, do you have an example image where just calling find_blobs() again on the roi of the previously found blob doesn't give you what you need followed by some filtering?
oramafanis
Re: blob region
Postby oramafanis » Fri Aug 07, 2020 3:25 am
hi friend!
i will manage to do some filtering to get my result for sure.
in this picture i want to count only the white blobs inside the big black circle blob for example.
can i use other regions except the rectangle?
Re: blob region
Postby kwagyeman » Fri Aug 07, 2020 1:37 pm
Just check if the little blobs rect intersects with the big blobs circle.
https://stackoverflow.com/questions/401 ... tersection
If you want a more general answer for any object... then I don't think we can do that as find_blobs() doesn't keep the contour of the blob for memory reasons.
oramafanis
Re: blob region
Postby oramafanis » Sat Aug 08, 2020 3:02 pm
Thank you ....
