Hello I hope I have not annoued you by my questions concerning C coding.
I have been investigating you omv project. Now I can create new methods for existing omv modules and compile native modules(.mpy files).
But current time I would like to create my own module which I can summon in OpenMV IDE by “import my_module” string.
I have created it but OpenMV IDE informed me that module wasn’t exist.
Seems that my module was compiled but not linked or my_module is not existed in OpenMV IDE database.
So my question is. Is it necessary to have names of modules in OpenMV IDE database to use it?
Hello.
Sorry for late reply. Too busy. I have not used OpenMV board for almost a year. Probably something can be changed for that year.
You can use existing micropython modules as examples. As I remember the logic was simple.
Open folder in your repository openmv/src/omv/py
Then create .c file. For example foo.c
This .c file contains you functions and other things
In .h file qstrdefsomv.h add following strings
Q(module’s name)
Q(module’s method name)
Q(second module’s method name)
etc
In folder openmv/src/micropython/ports/stm32 open file mpconfigport.h and add next string
extern const struct _mp_obj_module_t foo_module;
after #define MICROPY_PORT_BUILTIN_MODULES
you should add following string { MP_OBJ_NEW_QSTR(MP_QSTR_foo), (mp_obj_t)&foo_module },
It is made for registering you module in system
in makefile (in folder openmv/src ) you should add module’s object by using next string foo.o \ .
in makefile (in folder openmv/src/omv ) you should add string foo.c \ .
I can check this list in detail on weekends if it is necessary. Also you can google how to add your own module in micropython, it looks similar,
as I remember there was useful information about this topic.
