Updating WIFI shield
Raoof_M
Postby Raoof_M » Sat Apr 11, 2020 7:36 pm
I tried updating the WIFI shield firmware using the fw_update script but an error showed up (OSError: Could not find the file).
I copied the winc_19_6_1.bin file to a uSD card, then resetted the the camera but would always get the same result.
Re: Updating WIFI shield
Postby iabdalkader » Sat Apr 11, 2020 8:45 pm
Hi, please make sure the file is written, try safe remove/eject the drive before resetting the cam.
Raoof_M
Postby Raoof_M » Sat Apr 11, 2020 9:15 pm
I tried safe ejecting the drive then resetting the cam but the same error shows up.
is there any other way to update the WIFI shield ?
Postby iabdalkader » Sun Apr 12, 2020 7:42 am
You need to copy the file again, safe eject and then reset. There's another way to update using the debugging header on the wifi shield a power supply and Arduino (google WINC1500 firmware update) it's much more harder to update the firmware this way.
Users browsing this forum: kwagyeman and 8 guests
