Fixing and improving imlib_draw_image
mirkwood
Postby mirkwood » Sat Apr 11, 2020 6:00 am
I have improved the imlib_draw_image method by:
1/ *DONE* Fixing the broken application of alpha when using RGB565 images.
* The current release gives weird rainbow effects as the alpha value is just multiplied by the color value.
2/ *DONE* Adding the ability to pass a color palette when the other image is grayscale.
* This saves me having to allocate an extra RGB buffer for thermograph images allowing me to use higher resolution images.
3/ *PENDING INPUT FROM EVERYONE* Add some sort of ability to generate a smooth alpha if the other image is grayscale, so doubling the use of the other image as an alpha and an image.
* I think the simplest way to do this is if a 2 value tuple was passed represented (the grayscale value that would represent 0 alpha, the grayscale representing the maximum alpha). Then the function could just say anything under grayscale value of 0 alpha is invisible, between 0 alpha to maximum grayscale alpha is smoothed, and over maximum is just full alpha). Does that make sense/do you agree this is a good way to do it?
So the method becomes.
image.draw_image(image, x, y[, x_scale=1.0[, y_scale=1.0[, alpha=256[, mask=None, [color_palette, [alpha_smooth]]]]]])
Re: Fixing and improving imlib_draw_image
Postby kwagyeman » Sat Apr 11, 2020 12:03 pm
Can you send a PR on GitHub?
