Build OpenMV from source ,but...
Scott
Postby Scott » Wed Apr 08, 2020 4:08 am
hi! engineers from Openmv.
I strictly follow Linux Installation at https://github.com/openmv/openmv/wiki.
I'm sure I've used this method, "git clone -- recursive https://github.com/openmv/openmv.git".
But I met the following ERROR messages .
Use make V=1 or set BUILD_VERBOSE in your environment to increase build verbosity.
Warning: FROZEN_MPY_DIR is deprecated in favour of FROZEN_MANIFEST
MPY /home/zyf/Desktop/openmv/src/../scripts/libraries/ulinalg.py
../../py/mkrules.mk:129: recipe for target '/home/zyf/Desktop/openmv/src/build/micropython/frozen_mpy/ulinalg.mpy' failed
make[1]: ../../mpy-cross/mpy-cross: Command not found
make[1]: *** [/home/zyf/Desktop/openmv/src/build/micropython/frozen_mpy/ulinalg.mpy] Error 127
make: *** [FIRMWARE_OBJS] Error 2
Makefile:584: recipe for target 'FIRMWARE_OBJS' failed
15:41:37: The process "/usr/bin/make" exited with code 2.
Error while building/deploying project openmv (kit: Desktop Qt 5.11.1 GCC 64bit)
When executing step "Make"
15:41:37: Elapsed time: 00:14.
Can you please help?
Re: Build OpenMV from source ,but...
Postby iabdalkader » Wed Apr 08, 2020 7:41 am
you need to build the mpy cross compiler, cd micropython/my-cross and run make.
Scott
Postby Scott » Thu Apr 09, 2020 8:41 pm
Wow, the problem is solved. Thank you very much :D :D
tomas
Postby tomas » Wed Jun 03, 2020 3:54 pm
I'm trying to build the firmware. I'm using Ubuntu 18.04 (WSL on W10).
I've followed all steps specified on https://github.com/openmv/openmv/blob/m ... /README.md
but the last "make" command on the "src" directory (which builds the OpenMV Cam H7 Firmware) ends with this error:
CC src/flash.c
CC src/usbd_cdc.c
CC src/main.c
CC src/usbd_desc.c
CC src/qspif.c
make: python: Command not found
Makefile:617: recipe for target 'bootloader' failed
make: *** [bootloader] Error 127
Could you help me with this error?
Thanks a lot in advance.
Postby kwagyeman » Wed Jun 03, 2020 6:07 pm
Install python.
tomas
Postby tomas » Thu Jun 04, 2020 2:32 am
Sorry,
I had Python 3.6.9 already installed, I thought that it was compatible...
After running "sudo apt install python" and install Python 2.7.17 it works!
