OPENMV4 uasyncio Support
skylin008
Postby skylin008 » Mon Feb 24, 2020 11:02 pm
Hi, I had OPENMV4 board,need uasyncio support. The openmv4 firmware implies it is unable to run official uasyncio. The file core.py in uasyncio uses ucollections.dequeue, and this is provided by the file py/modcollections.c in the source tree. Please help me,Kindly Thanks!
Re: OPENMV4 uasyncio Support
Postby iabdalkader » Tue Feb 25, 2020 9:43 am
The deque is enabled now.
skylin008
Postby skylin008 » Thu Feb 27, 2020 10:03 pm
hi @iabdalkader, I had update the openmv4 firmware,the version is 3.6, the detail is : MicroPython v1.12-omv OpenMV v3.6.0 2020-02-07; OPENMV4-STM32H743. But when I used the uasyncio,the error as show: AttributeError: 'module' object has no attribute 'deque'.Does version 3.6 had include the deque? Thanks !
The code as follow:
import uasyncio as asyncio
from pyb import UART
uart = UART(3, 9600)
async def sender():
    swriter = asyncio.StreamWriter(uart, {})
        await swriter.awrite('Hello uart\n')
        await asyncio.sleep(2)
async def receiver():
    sreader = asyncio.StreamReader(uart)
        res = await sreader.readline()
        print('Recieved', res)
loop = asyncio.get_event_loop()
loop.create_task(sender())
loop.create_task(receiver())
loop.run_forever()
Postby iabdalkader » Fri Mar 06, 2020 6:24 am
Hi, sorry for the delay I thought I replied to this... The deque is enabled if you build from source, otherwise it will be available in the next release.
Users browsing this forum: No registered users and 24 guests
