MemoryError
OpenMV noob
MemoryError
Postby OpenMV noob » Fri Feb 21, 2020 11:52 am
Hello, I have a problem with QRcodes detection, every time when I run program, I get next error: 'MemoryError: Out of fast Frame Buffer Stack Memory! Please reduce the resolution of the image you are running this algorithm on to bypss this issue'. Help please. Thanks for answer.
Re: MemoryError
Postby kwagyeman » Fri Feb 21, 2020 1:34 pm
What resolution and camera are you running the code on? You shouldn't have a problem with the H7/M7 at QQVGA.
OpenMV noob
Re: MemoryError
Postby OpenMV noob » Fri Feb 28, 2020 10:13 am
I use OpenMV Cam M4 - OV7725, resolution: QVGA. And now I have another question: can Open MV detekt for example qrcodes and lines at the same time?
Re: MemoryError
Postby kwagyeman » Fri Feb 28, 2020 1:25 pm
The M4 doesn't have enough RAM and qrcodes are disabled for it because of that.
Users browsing this forum: No registered users and 12 guests
