Script is deleted after turning on and off the power supply
Justas
Postby Justas » Wed Feb 19, 2020 1:11 am
I am using OpenMV H7 camera. When I save the script by "save open script to openmv cam", turn off the power then turn it back on, the code inside deletes itself. Is this a faulty camera or is this fixable?
Re: Script is deleted after turning on and off the power supply
Postby kwagyeman » Wed Feb 19, 2020 2:13 am
Hi, can you eject the OpenMV Cam disk after running that command before powering the system off? The write most likely did not happen to the camera disk. (The internal uPY drive is FAT12 which causes OS drivers to treat it not like a standard USB key and do writes immediately).
Users browsing this forum: No registered users and 14 guests
