Serial comunication with Arduino
GiusB
Postby GiusB » Fri Jan 24, 2020 5:32 am
Hello!
I need to create a comunication between OpenMV serial and Arduino serial: I want to read data from the first one and print them on the second one.
I did this program on OpenMV (cables connected at P4/P5 of camera):
from pyb import UART
uart = UART(3,9600, timeout_char = 1000)
thresholds_index = 0 #for yellow
# The below thresholds track in general yellow things.
thresholds = [(50, 100,-20,20, 30, 100)] # generic_yellow_thresholds
sensor.set_framesize(sensor.HQVGA) #240x160
sensor.skip_frames(30)
# Do your regular OpenMV image processing / etc
# camera resolution. "merge=True" must be set to merge overlapping color blobs for color codes.
clock.avg()
img = sensor.snapshot().lens_corr(strength=1.8, zoom=1.0)
for blob in img.find_blobs([thresholds[thresholds_index]], pixels_threshold=50, area_threshold=50, merge=True):
x= blob.cx()/13.1*2.54
y= blob.cy()/13.1*2.54
uart.write("%d\n"%x)
uart.write("%d\n"%y)
print("x: %d\n"%x, end='')
print("y: %d\n"%y)
#print(clock.avg())
Arduino( MEGA) Code:
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); // RX, TX
void setup() {
Serial.begin(9600);
mySerial.begin(9600);
void loop(){
if (mySerial.available()){
delay(100); // Wait for all data.
while (mySerial.available()) {
char d = mySerial.read();
str.concat(d);
char t[str.length()+1];
str.toCharArray(t, (sizeof(t)));
int intdata = atoi(t);
Serial.print(intdata);
Serial.print("\n");
delay(100);
But I don't have any results.
Thanks for the help!
Re: Serial comunication with Arduino
Postby kwagyeman » Fri Jan 24, 2020 12:38 pm
Can you wrap your code in the code tags the forum has so it's more readable and fix the indentation?
GiusB
Postby GiusB » Mon Jan 27, 2020 3:34 am
OpenMV code:
# Yellow Color Code Tracking
    clock.avg()
            print("%d\n"%x,end="")
            print("%d\n"%y)
            #print(clock.avg())
Arduino code:
String str
void setup() {
Serial.begin(9600);
void loop(){
str.concat(d);
Serial.print("\n");
delay(100);
Postby kwagyeman » Mon Jan 27, 2020 11:52 am
Okay, your program on the OpenMV Cam is fine. The one on the Arduino isn't written in a way that it will receive text easily.
Arduino supports a method called parse_int which can read an int on the serial port and will handle receiving data for you. Can you use that method to read the two unit values you send and then print what parse_int returns?
