Max frame rate / ROI
anderi
Postby anderi » Mon Oct 17, 2016 10:32 am
Hi, I just bought a couple of OpenMV cameras for a project where I need to detect linear 1d markers (basically a barcode), the algorithms run fine but I need to increase the framerate.
Since I'm only interested in one (or a couple of) line of the image, is there any way to reduce the data transferred from the sensor to the stm32 to increase framerate?
Best regards,
Andreas
Re: Max frame rate / ROI
Postby iabdalkader » Mon Oct 17, 2016 10:56 am
Yes, if the function accepts a ROI you could pass ROI info in a tuple ( image.function(..., roi=(x, y, w, h)). We're working on making all functions accept ROI argument, but if a function doesn't support ROIs yet, you could reduce the frame size setting the windowing. For example, the following sets the frame size to (80x60) from a VGA frame, this gives you higher resolution with less data to process:
sensor.set_windowing(((640-80)//2, (480-60)//2, 80, 60))
anderi
Postby anderi » Tue Oct 18, 2016 7:50 am
Wow, thanks for the fast reply! That works flawlessly!
Regards,
Andreas
Users browsing this forum: No registered users and 21 guests
