Problems with Wifi Shield
lawrie
Postby lawrie » Sun Oct 09, 2016 4:13 pm
I am having problems with the Wifi shield.
Most of the examples in the IDE work except that tcp_client_1.py returns no data, and any other socket server I have tried returns no data,or returns random data.
I am trying to send an http message to a node red server when I detect a face. It occasionally works once, never twice, and never when I use it in my intended way.
This is the code:
def say():
    client = usocket.socket(usocket.AF_INET, usocket.SOCK_STREAM)
        client.connect(('192.168.0.101', 1880))
        client.settimeout(5.0)
    except OSError as er:
        print("Error from connect: " + str(er))
        client.send("GET /camera?say=Hello HTTP/1.0\r\n\r\n")
        reply = client.recv(128).decode("utf-8")
        print("Error from send: " + str(er))
    client.close()
I usually get error 116 from send on the first call, and error -9 from connect on subsequent calls.
Am I doing something wrong. Are the OS errors listed anywhere?
Re: Problems with Wifi Shield
Postby iabdalkader » Sun Oct 09, 2016 4:51 pm
Do you get errors/exceptions when trying tcp_clinet.py ? It shouldn't return any data just an empty string.
Also you should make sure the module is connected, it should print some info after "Trying to connect..." (BSSI, SSID, mac, and IP) does it print that ?
Error numbers are the same ones in errno.h (except -1 is an internal error in the sockets library).
116 is timeout (should actually be negative)
-9 is a bad FD, probably closed or not bound for a server socket.
Postby iabdalkader » Sun Oct 09, 2016 5:14 pm
umm so there's a bug in the recv function, it doesn't return the number of bytes which causes the higher level wrapper to think it got 0 bytes. I'm going to fix this in the next release, but since you're working on something right now I'm attaching a patched firmware, this firmware image also has debugging printf's enabled to help us debug if there are more issues with the WiFi/sockets code.
OMV2-RECV-FIX.zip
(1.32 MiB) Downloaded 151 times
lawrie
Postby lawrie » Mon Oct 10, 2016 5:01 am
I tried to use your new firmware by unzipping in and selecting the bin file in the "Run Bootloader" IDE option. It appeared to work, but the IDE will not let me connect to the device unless I upgrade the firmware, which I assume will put it back to the release version. Is there any way round this?
lawrie
Postby lawrie » Mon Oct 10, 2016 5:36 am
I should not be getting the bad FD response, as you can see from my code that I have just created the socket and it is a client socket.
The 116 errors occur randomly but most of the time on nearly any web site. The value is positive.
I think the bad FD response happens on all connect calls after the 116 error has occurred, even when a new socket is created.
(If I just close a socket and then attempt a new connect on the same socket, I get a -6 response).
lawrie
Postby lawrie » Mon Oct 10, 2016 5:53 am
In tcp_client_1.py, if I change the web site from "www.google.com" to "www.bbc.co.uk" (for example), I get the 116 error.
Postby kwagyeman » Mon Oct 10, 2016 9:22 am
Hi, to get around the IDE issue there's a file in the IDE dir called share/QtCreator/firmware/version.txt. Make the version number 2.0.0.
Postby iabdalkader » Mon Oct 10, 2016 10:24 am
lawrie wrote:I should not be getting the bad FD response, as you can see from my code that I have just created the socket and it is a client socket.
It could be another issue with the FW, please try the patched FW image (you can edit the firmware.txt file to bypass the IDE check just like Kwabena mentioned), the patched FW prints some debugging message, if you're still having issues send me the log and I'll look into it.
lawrie
Postby lawrie » Mon Oct 10, 2016 1:55 pm
Hi the new firmware fixed the problem with the reply in tcp_client_1.py. I am now getting HTML back, although it is slightly odd what it prints:
>>> Trying to connect... (may take a while)...
[-56, 2, 'virginmedia6527155', 'f8:f0:05:f6:83:b5', '192.168.0.19']
socket_callback(): connect success.
</BODY></HTML>\r\n'
I still have the other two problems:
[-52, 2, 'virginmedia6527155', 'f8:f0:05:f6:83:b5', '192.168.0.19']
wifi_callback(): Unknown message type: 27
Error from send: 116
and
Error from connect: -9
In the second case, there is no other diagnostics.
The code is still as above. The first case is where I call say() at the start of the program. The second is when I call it after detecting a face.
Postby iabdalkader » Mon Oct 10, 2016 6:11 pm
Hi, the tcp_client.py prints the whole page at least when I run it here, the output looks like this:
socket_callback(): recv 479
b'HTTP/1.0 302 Found\r\nCache-Control: private\r\nContent-Type: text/html ....
I think in the first case recv is timing out, your exception handler is around send/recv so I'm not sure which one is failing.. Anyway, most calls were set to timeout after 1000ms regardless of the timeout set with settimeout(), I fixed this issue now to use the timeout passed in settimeout(), passing 0 means block forever. I'm attaching another FW image.
I'm not sure about the second case (-9), I get -9 when the socket is closed, anyway, please post the whole script again after testing this fw image.
firmware.bin.zip
(673.85 KiB) Downloaded 149 times
lawrie
Postby lawrie » Tue Oct 11, 2016 3:12 am
I am still getting the same errors, even with a high timeout. The error is now being reported as -116 (i.e negative).
I have changed the script slightly. Here is the full script:
import sensor, time, image,pyb, sys
import network, usocket
# AP info
SSID='virginmedia6527155' # Network SSID
KEY='********  # Network key
wlan = network.WINC()
wlan.connect(SSID, key=KEY, security=wlan.WPA_PSK)
print(wlan.ifconfig())
def say():
        client.settimeout(20.0)
            reply = client.recv(256).decode("utf-8")
            print(reply)
    client.close()
say()
s1 = pyb.Servo(1) # P7
s2 = pyb.Servo(2) # P8
sw = 240
sh = 160
x_angle = 0
y_angle = -30
def blink():
    led = pyb.LED(2) # Use green LED.
    led.on()
    time.sleep(150)
    led.off()
    time.sleep(100)
    led.on()
    time.sleep(150)
    led.off()
# Reset sensor
# Sensor settings
sensor.set_contrast(1)
sensor.set_gainceiling(16)
# HQVGA and GRAYSCALE are the best for face tracking.
sensor.set_framesize(sensor.HQVGA)
# Load Haar Cascade
# FPS clock
# Flip display
sensor.__write_reg(0x0C, sensor.__read_reg(0x0C) | (1 << 7))
while (True):
    s1.angle(y_angle)
    s2.angle(x_angle)
    # Capture snapshot
    # Find objects.
    # Note: Lower scale factor scales-down the image more and detects smaller objects.
    # Higher threshold results in a higher detection rate, with more false positives.
    objects = img.find_features(face_cascade, threshold=0.5, scale=1.5)
    if objects:
        blink()
        say()
    # Draw objects
    for r in objects:
        img.draw_rectangle(r)
        print(r)
        w = (sw - r[2])/2
        h = (sh - r[3])/2
        x_angle -= (w - r[0])/10
        y_angle -= (h - r[1])/10
lawrie
Postby lawrie » Tue Oct 11, 2016 3:18 am
Here is the output when the first call to say() worked:
>>> [-50, 2, 'virginmedia6527155', 'f8:f0:05:f6:83:b5', '192.168.0.19']
socket_callback(): recv 195
HTTP/1.1 200 OK
X-Powered-By: Express
Content-Length: 2
Content-Type: text/html; charset=utf-8
ETag: W/"2-REvLOj/Pg4kpbElGfyfh1g"
Date: Tue, 11 Oct 2016 07:04:27 GMT
Connection: close
ok
(66, 30, 122, 122)
(30, 3, 81, 81)
And here is output when it failed:
>>> [-51, 2, 'virginmedia6527155', 'f8:f0:05:f6:83:b5', '192.168.0.19']
Error from send: -116
(53, 10, 122, 122)
(56, 5, 122, 122)
In all cases the call of say() after face detection fails on connect with error -9.
Postby iabdalkader » Tue Oct 11, 2016 10:26 am
I think I see the problem...You can't use the WiFi shield and servos at the same time, the WiFi shield uses all pins except UART/I2C on the left header. That's why the first say() works because it's called before changing I/Os to PWM, you could confirm that by commenting the servo. If you must use WiFi + servos you could use UART/I2C to another board control them.
lawrie
Postby lawrie » Tue Oct 11, 2016 11:38 am
It works slightly better with the servos commented out.
The initial say() still fails most of the time with the -116 error. And if it fails, all subsequent calls to say() fail. Like this:
>>> [-47, 2, 'virginmedia6527155', 'f8:f0:05:f6:83:b5', '192.168.0.19']
socket_callback(): connect error!
Error from send: -9
(91, 7, 81, 81)
If I keep trying the first call to say() occasionally works, and if it does all subsequent calls work. It seems to work about 1 in 5 times. The timeout does not seem to matter. It works as well with timeout 1.0 as any other value.
lawrie
Postby lawrie » Tue Oct 11, 2016 11:45 am
I did not realise that the Wifi shield would stop other things from working. (Perhaps I should have guessed, and checked). It will make the project I want to do harder.
A version of OpenMV based in an ESP32, with Wifi and Bluetooth built-in, would be good, if that were possible.
Postby iabdalkader » Tue Oct 11, 2016 12:31 pm
lawrie wrote:I did not realise that the Wifi shield would stop other things from working. (Perhaps I should have guessed, and checked). It will make the project I want to do harder.
Unfortunately the code doesn't detect conflicts it just lets you do whatever you want, maybe this should be fixed. Anyway, one of the PWM pins is connected to the WiFi shield reset pin, probably why you get bad FD. There's another timer on P4 and P5 (the unused pins) but it's not currently used for servos, will see if I can enabled those in the next FW release.
lawrie wrote:A version of OpenMV based in an ESP32, with Wifi and Bluetooth built-in, would be good, if that were possible.
We're working on an M7 cam, 216MHz dual issue, 512KBs SRAM + SDRAM, HW JPEG and it has more I/Os.
lawrie
Postby lawrie » Tue Oct 11, 2016 12:57 pm
Did you see from my previous reply that I am still having problems with the Wifi shield even when I don't use the servos. I can only connect to my web site about 1 in 5 times, and when it fails, it fails all subsequent times, until I restart the program.
Postby iabdalkader » Tue Oct 11, 2016 1:05 pm
lawrie wrote:Did you see from my previous reply that I am still having problems with the Wifi shield even when I don't use the servos. I can only connect to my web site about 1 in 5 times, and when it fails, it fails all subsequent times, until I restart the program.
Nope, I missed it, I'll test your script now without servos.
lawrie
Postby lawrie » Tue Oct 11, 2016 1:15 pm
The problem of the -116 error has not been fixed by any of your changes or by not using servos. Setting a timeout bigger than 1.0 does not make connection work any better, it just makes it fail slower.
Postby iabdalkader » Tue Oct 11, 2016 2:19 pm
So I tested your script using the following host side script:
import sys, socket
HOST = ''   # Symbolic name, meaning all available interfaces
PORT = 1880 # Arbitrary non-privileged port
s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
s.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
print ('Socket created')
#Bind socket to local host and port
    s.bind((HOST, PORT))
except socket.error as msg:
    print ('Bind failed. Error Code : ' + str(msg[0]) + ' Message ' + msg[1])
    sys.exit()
print ('Socket bind complete')
#Start listening on socket
s.listen(10)
#now keep talking with the client
while 1:
        #wait to accept a connection - blocking call
        print("Waiting for connections...")
        client, addr = s.accept()
        print('Connected to ' + addr[0] + ':' + str(addr[1]))
        data = client.recv(1024)
        client.send("Hello from server!")
        client.close()
        print ('Connection failed. Error: ' + str(msg))
        client.close()
s.close()
I noticed that only the first say() fails, then it runs normally, adding a delay after connect to network seems to make the first say() work, not sure why, will look into it further but for now you could just remove the first say(), also made small changes to the script :
# AP info
SSID=''     # Network SSID
KEY=''      # Network key
def say():
        client.settimeout(2.0)
        client.close()
        print(reply)
    except Exception as e:
        print("Error : " + str(e))
def blink():
    led.on()
    time.sleep(150)
    led.off()
    time.sleep(100)
    led.on()
    time.sleep(150)
    led.off()
# Reset sensor
# Sensor settings
# Flip display
sensor.set_vflip(True)
# Load Haar Cascade
# FPS clock
while (True):
    # Capture snapshot
    # Find objects.
    if objects:
        blink()
        say()
    # Draw objects
    for r in objects:
        print(r)
Note you can use sensor.set_vflip(True) to flip upside down, and image.width/height() to get frame dimensions.
lawrie
Postby lawrie » Tue Oct 11, 2016 3:40 pm
Thanks, it's working reliably now.
lawrie
Postby lawrie » Tue Oct 11, 2016 4:16 pm
The project I am attempting is a social robot that detects people, tracks their faces, and follows them about, and talks to them.
I am using text to speech via node-red on a Raspberry Pi.
I have an ESP8266 driving the robot base. The camera is on an Adafruit pan-tilt kit on the robot base.
I will probably send the face rectangle to the ESP8266 via Wifi and get it to do the pan and tilt as well as the robot movement. Or if necessary, I will use a serial link to the ESP8266.
I might send the image of the face to a server so it can do recognition of specific people, probably using OpenCV.
I might link the robot to Amazon Alexa via the Raspberry Pi, so I can ask it questions and get it to control my house.
Postby kwagyeman » Tue Oct 11, 2016 6:30 pm
We looked into using the EPS32 for this. Unfortunately they didn't add a camera interface so one of the two cores will have to spend more or less 100% of the time capturing images always since it would have to go into an interrupt routine to poll a 24 MHz clock source from the camera constantly. The other core will be tied up with WiFi/BLE. Anyway, such a system could work... but, there would be little time for actual image processing.
Anyway, keep letting us know what you need help with! Thanks for being an early user. We're going to keep making the system better and better.
wminarik
Postby wminarik » Wed Oct 19, 2016 10:56 pm
I've just starting using a WiFi shield...
and I'm stuck at the first step:
>>>import network
hangs with no message and requires a restart to clear. This is true both with the default firmware:
v1.8-4344-gc9d17c1 on 2016-09-20
and with the patched version
v1.8-4345-g3a2670b on 2016-10-11
posted above.
Other modules, including the camera, seem to work fine. Any ideas?
Thanks in advance,
Bill
P.S. The IDE firmware version file location on Mac OS is: /OpenMV IDE.app/Contents/Resources/firmware
Postby iabdalkader » Thu Oct 20, 2016 11:40 am
wminarik wrote:I've just starting using a WiFi shield...
>>>import network
posted above.
Thanks in advance,
Bill
Looks like the cam can't detect the WiFi module, it's definitely not a FW problem. First make sure all the pins are connected all the way, if it's still doesn't work send us an email [email protected] it might be a bad module.
wminarik
Wifi Shield Physical Connection
Postby wminarik » Fri Oct 21, 2016 8:55 am
Solved: It was a pin connection issue.
I initially didn't think this was the case: the pins seated well, I had power and ground, and a second shield placed on top of the WiFi shield worked fine (the thermal shield (which uses I2C)). After checking the through-connectivity of each pin, one pin that the WiFi shield uses wasn't connecting. Swapping to another OpenMV board didn't help; this time there there were two SPI pins that didn't connect. I managed to get the WiFi shield working by connecting each pin to the OpenMV header using jumper wires.
It appears that with this set of stacking pins&headers, slight misalignment between the two sets on each board (due to the way they were solders) can cause some individual pins to not make contact. I didn't know the design permitted this...
Now that WiFi connects, on to the software...
Postby kwagyeman » Fri Oct 21, 2016 8:58 am
Can you post a picture?
wminarik
Postby wminarik » Sat Oct 22, 2016 7:07 pm
OK, Here you go:
Doesn't work; P1 or P2 do not connect (I've beeped out the connections several times with a multimeter, and wiggled it every way I can imagine) (swapping OpenMV main boards gives the same syptoms, but with other pins):
WiFi shield does not make connections on all pins.
The WiFi shield works with jumpers (I ran out of jumper wires of the same length):
WiFi shield connected using jumper wires
Works (WIFi Shield in back):
WiFi shield works when mounted in back.
Works (Thermal shield) (uses the I2C bus):
Thermal shield connects with the pins it needs.
The pins are seated as far into the female headers as they will go... As far as I can tell, it's something to do with the way the pin mates with the header when the rows are slightly misaligned. I'm tempted to de-solder the headers and put shorter ones on, but I'm not sure how much EM clearance the WiFI needs.
Bill
Postby kwagyeman » Sat Oct 22, 2016 9:10 pm
This is probably a manufacturing issue with the headers...
I see what MacroFab can do to address this. Thanks for posting.
