Catching the IDE "stop" in uPython
petri
Postby petri » Tue Aug 23, 2016 1:39 am
How does the IDE stop the running uPython program on the camera? Does it send some sort of signal for which a handler could be registered? Or does it reset the camera in a way that is outside of uPython control or what?
It would be useful to be able to catch the stop.
UPDATE: I noticed the serial terminal echoing something like "Exception: IDE interrupt" ... ?
Re: Catching the IDE "stop" in uPython
Postby kwagyeman » Tue Aug 23, 2016 9:35 am
It resets the scripts outside of uPython control. Anyway, we are about to do a release. Maybe Ibrahim can add something you need. Can you describe it?
Postby iabdalkader » Tue Aug 23, 2016 10:35 am
petri wrote:How does the IDE stop the running uPython program on the camera? Does it send some sort of signal for which a handler could be registered? Or does it reset the camera in a way that is outside of uPython control or what?
The IDE sends a packet over USB/CDC to pend/raise an exception which interrupts uPython, and yes you can catch this exception and handle it, however the IDE won't be able to stop the script if you do, additionally, the handler disables the USB FS interrupt before raising this exception, and it's re-enabled before executing another script or REPL.
