JS8019
1
Good Day,
I need to have more resolution in the Brightness settings. I have used sensor.set_brightness(), but the inputs are limited to -3 to +3.
I guess I will have to modify this code and re-build?
https://github.com/openmv/openmv/blob/master/src/omv/ov9650.c#L295
Or is there an easier way?
Best,
Jack
Um, are you using the OV7725 camera?
Anyway, just use this function: https://openmv.io/docs/library/omv.image.html#image.image.morph
You can adjust the image brightness/contrast with it.
you can use sensor.__write_reg(addr, value) for quick testing.
JS8019
4
Thanks! If I can get sensor.__write_reg(addr, value) to work, that will be VERY helpful in speeding up my workflow.
I have the $70 “OPENMV CAM”.
Use the write reg function to set registers.
