img-chars74k.network network module missing,
bob63
Postby bob63 » Thu Apr 25, 2019 8:25 am
Hi , I've just received my H7 and try to use the machine learning example on IDE 2.2.0.
Locking the nn_chars74k_2.py example I was expecting to find into the network models folder the 3 files mentioned as possible alternatives,but is available just the fnt-chars74k.network.
Another doubt is about the line "works hand written chars" and the one" for printed font" that seems use the same network module . Is it correct or is a typo error ?
# Load chars74 network
net = nn.load('/fnt-chars74k.network') # works on printed font
# net = nn.load('/fnt-chars74k.network') # works on handwritten chars
# net = nn.load('/img-chars74k.network') # works on images of chars
Re: img-chars74k.network network module missing,
Postby kwagyeman » Thu Apr 25, 2019 8:10 pm
Hi, sorry, I was in a rush releasing that script. The other two networks don't work. I haven't bothered to release them. Please delete those two lines. I have a write-up on how to train the other two networks but they score very low.
And yes, it's a typo with the second network. Um, here's the GitHub link to how those were trained: https://github.com/kwagyeman/openmv/blo ... ecognition
bob63
Postby bob63 » Fri Apr 26, 2019 3:45 am
OK ! No problems ...
Thanks.
Pooyan
Postby Pooyan » Wed Jan 29, 2020 9:11 am
Hi I am working on a project in which the camera should detect these characters ( H , S ,U ) and my camera model is M7 I'll be thankful if you help me
Postby kwagyeman » Wed Jan 29, 2020 10:07 am
What are you having an issue with?
Pooyan
Postby Pooyan » Wed Jan 29, 2020 10:36 am
actually it's the first time that I am using this camera and I am not familiar with it so I search in YouTube and I find this example but my open Mv cam gives an OSError in the line 17 and says could not find the file ( my camera model is M7 ) and I don't know what should I do now I'll be thankful if you guide me and if I am wrong could you please tell me the right way . Thanks
This is the example which l find :
# Chars74K CNN Example
# This example shows off how to use the OpenMV Cam to detect
# characters 0-9 A-Z a-z.
import sensor, image, time, os, nn
sensor.set_pixformat(sensor.GRAYSCALE) # Set pixel format to GRAYSCALE
sensor.set_windowing((128, 128))       # Set 128x128 window.
sensor.skip_frames(time=500)
sensor.set_auto_gain(False)
sensor.set_auto_exposure(False)
 👉 the problem is in the previous line
labels = ['n/a', '0', '1', '2', '3', '4', '5', '6', '7', '8', '9']
for i in range(ord('A'), ord('Z') + 1): labels.append(chr(i))
for i in range(ord('a'), ord('z') + 1): labels.append(chr(i))
    clock.tick()                    # Update the FPS clock.
    out = net.forward(img.binary([(200, 255)]), softmax=True)
    max_idx = out.index(max(out))
    score = int(out[max_idx]*100)
    if (score < 50):
        score_str = "??:??%"
        score_str = "%s:%d%% "%(labels[max_idx], score)
    img.draw_string(0, 0, score_str, color=(255, 0, 0))
    print(clock.fps())             # Note: OpenMV Cam runs about half as fast when connected
Postby iabdalkader » Wed Jan 29, 2020 12:03 pm
You just need to copy this network to SD and the run the script, but I don't think we have that network.
Pooyan
Postby Pooyan » Wed Jan 29, 2020 12:27 pm
Thank you very much for your help .
I'll be thankful if you could tell me where can I find or search for this network ?
Postby kwagyeman » Wed Jan 29, 2020 1:51 pm
Tools->Machine Vision->CNN Network Library in the IDE.
Pooyan
Postby Pooyan » Wed Jan 29, 2020 2:41 pm
Thank you
Users browsing this forum: No registered users and 12 guests
