Difficulties Connecting
Re: Difficulties Connecting
"@Kermit666 - Inability to connect is a separate issue from the USB packets. When you plug in your OpenMV Cam... does it appear as a device in your device manager? If so, what device does it appear as? There's no IDE fix I can do to solve any problem related to the Cam not connecting to the PC initially."
When I plug in the Cam it appears as a removable disk, with 31 KB and 3 files inside.
This works perfectly from the beginning
"Two things can be happening:
1. The wrong driver is getting loaded for your OpenMV Cam.
2. The Cam's firmware is bad and you need the bootloader to fix it. If 2 is the case the bootloader should be able to connect to the Cam, but, might have trouble re flashing given the packet issue. You'd get a failed to connect to bootloader error here."
I have the lcd module, what happens on the lcd module when I connect the cam ? on my cam + lcd I have only a white lcd, nothing else !
Hi, you have to run the LCD demo script. The cam has to be told to update the LCD. Don't worry, adding LCD to your code is only 1 line.
Deshipu,
Qt has no easy way using the http://doc.qt.io/qt-5/qstorageinfo.html class to filter out EFI partitions.
I'll make another installer for linux with a fix to ignore the drive if EFI is in it's name. However, I need to focus on other things right now.
Wait, I have a fix. I'll filter out all drives not mounted in media.
That sounds reasonable. Perhaps it would be good to have a way to bypass the filtering altogether, in case of a really weird system setup -- for instance, a button that makes it display all mounted drives, or even lets you just enter a path.
After updating as prompted the board is completely unresponsive. Does not show up in devices. LED no longer lit.
I tried several different USB connectors.
It's dead Jim.
It's dead Jim.
Hi, you can use DFU mode to recover it. On windows the IDE will walk you through this process without requring external software. On Mac and Linux you need to make sure you have some external libraries installed first.
Anyway, Just click the connect button and follow the IDE prompts.
Links to Mac and Linux stuff:
https://github.com/openmv/openmv/wiki/L ... stallation
https://github.com/openmv/openmv/wiki/M ... stallation
The IDE will literally ask you on connect if your OpenMV Cam is bricked - follow the prompts from there.
Note, once the system starts scanning for your OpenMV Cam just click the cancel button and the IDE will ask you if you want to use the DFU bootloader, say yes.
It says "DFU firmware update failed".
Hi, can you give some more info? It really helps.
So, what operating system are you using? Did you connect the cam to the PC before clicking "ok" to run the DFU update? Did you attach a jumper wire between BOOT0 and the 3.3V pin or RST?
On windows, if you plug in the cam when it's in DFU mode it should appear as a USB device and windows will load up the driver for it and make the USB connection sound. If you hear that then you know the board is ready for DFU updating.
Back to fail msg.
- Attachments
- Screenshot 2016-12-09 19.01.07.jpg (22.19 KiB) Viewed 7547 times
Windows 10 - 64 bit
jumper connected.
jumper connected.
Hmmm, you'd only get that if the DFU update hung. DFU should basically error out immediately if there's a problem or work. Not hang.
Okay, let me send out another board to you. I have an extra one at home with me I can provision and test to make sure it works before sending it to you. Please email openmv your address.
Um, however, in the email, can you confirm that windows sees a device when you plug the camera into your computer in DFU mode? Windows should pop up some text about an STM DFU device being attached.
I hear the Windows connection tone but there's no message.
You should see this in the device manager.
If that's the case I'm not sure why you are having problems. DFU should work.
Anyway, I can provide another Cam program and tested by me.
- Attachments
- Untitled.png (16.48 KiB) Viewed 7542 times
It says "Unknown USB Device (Device Descriptor Request Failed)
It only sees the board with the jumper on.
Yeah... that shouldn't happen. Um, anyway, please send me your address via email so I can send a replacement.
I sent you my address. Let me know if you can't find it.
Norm
Norm
On the way.
Norm
Norm
Got it and everything seems to be working.
