In between lockups, I exit the IDE and unplug the module
[875424.766530] usb 2-1.2.2: new full-speed USB device number 36 using ehci-pci
[875424.877244] usb 2-1.2.2: New USB device found, idVendor=1209, idProduct=abd1
[875424.877254] usb 2-1.2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[875424.877260] usb 2-1.2.2: Product: OpenMV Virtual Comm Port in FS Mode
[875424.877265] usb 2-1.2.2: Manufacturer: OpenMV
[875424.877269] usb 2-1.2.2: SerialNumber: 000000000011
[875424.877737] cdc_acm 2-1.2.2:1.0: ttyACM0: USB ACM device
[875424.878104] usb-storage 2-1.2.2:1.2: USB Mass Storage device detected
[875424.878335] scsi host35: usb-storage 2-1.2.2:1.2
[875425.876142] scsi 35:0:0:0: Direct-Access uPy microSD Flash 1.00 PQ: 0 ANSI: 2
[875425.876602] sd 35:0:0:0: Attached scsi generic sg2 type 0
[875425.877351] sd 35:0:0:0: [sdc] 97 512-byte logical blocks: (49.6 kB/48.5 KiB)
[875425.877968] sd 35:0:0:0: [sdc] Write Protect is off
[875425.877975] sd 35:0:0:0: [sdc] Mode Sense: 00 00 00 00
[875425.878592] sd 35:0:0:0: [sdc] Asking for cache data failed
[875425.878598] sd 35:0:0:0: [sdc] Assuming drive cache: write through
[875425.888105] sdc: sdc1
[875425.891214] sd 35:0:0:0: [sdc] Attached SCSI removable disk
[875431.746159] FAT-fs (sdc1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
