apriltag.corners() to subpixel precision ?
ecdm2
Postby ecdm2 » Sat Dec 08, 2018 7:28 am
Hello
In Olson's 2011 AprilTag paper he states that the:
" ... corner estimates are accurate to a small fraction of a pixel."
I've been using the apriltag.corners() to get the corner positions of the tags but they are only returned with pixel (integer) precision.
Could you change this in the C/C++ firmware so that the corner positions are returned as floating point - tenths or hundredths of a pixel precision ?
I would like to use the OpenMV cam and AprilTags to measure camera position.
I was hoping to take the corner positions from OpenMV into OpenCV and, together with the 'known' corner positions for a printed array of tags, use them with solvePnP to calibrate the output from apriltag.x_ , y_ and z_translation.
Please note that this is not the same as camera calibration for fx, fy, cx and cy - I've done that separately.
Best Wishes,
Ed
Re: apriltag.corners() to subpixel precision ?
Postby kwagyeman » Sat Dec 08, 2018 11:09 pm
Yes, we can enable this. However, if you can do a PR it will get in faster:
The corners are stored here:
https://github.com/openmv/openmv/blob/m ... g.c#L11724
The values are stored in this struct:
https://github.com/openmv/openmv/blob/m ... ib.h#L1095
And the access methods for python are here:
https://github.com/openmv/openmv/blob/m ... ge.c#L4378
And the python keywords are here:
https://github.com/openmv/openmv/blob/m ... omv.h#L880
It's straight forward to edit the code to add in what you need. If you can't make a PR for this then create a bug tracker on github for the feature.
ecdm2
Postby ecdm2 » Sun Dec 09, 2018 5:07 am
Thank You Kwabena
I'm not that familiar with C / Cython and I'm really pressed with project demands at the moment. Ironically this looks looks like a good place to start getting familiar with the firmware.
I've submitted as an issue on GitHub for now anyway. Hope that is OK.
Best,
Ed
Postby kwagyeman » Sun Dec 09, 2018 12:33 pm
Okay. This will amke it in eventually. I'll have a lot of time to work soon.
