.inf woes
moloned
.inf woes
Postby moloned » Tue May 31, 2016 12:46 pm
I tried following the instructions provided in the intro section
http://openmv.io/docs/openmv/tutorial/intro.html
unfortunately I can's seem to install the driver
The IDE works but I can't connect with the board for this reason
I seem to be able to edit the main.py but I get a save failed error
Any suggestions?
moloned
Re: .inf woes
Postby moloned » Tue May 31, 2016 12:52 pm
The save failed error seems to relate to a corrupted main.py
The problem with the inf remains however
Re: .inf woes
Postby kwagyeman » Tue May 31, 2016 1:58 pm
Please follow this guide here: https://micropython.org/resources/Micro ... -setup.pdf
If you're using a newer windows version you have to install the driver is a very awkward way which involves shutting down your PC to put it into safe mode.
You need the driver however, otherwise, things won't work.
(Not sure why you can see the old tutorial - please disregard that documentation, please access docs using just the docs link and not any sub links).
moloned
Re: .inf woes
Postby moloned » Wed Jun 01, 2016 9:27 am
I tried the IDE and everything now seems to Work
I think if the Execute button were green and not gray
I think it would be a help in terms of your IDE
For this reason it seems like it is grayed out and hence not working
Anyway all good for now and I'm having fun playing with the examples
