# AprilTags with Dynamic ROI Example
# This script will track a single tag by searching a continuosly redefined (dynamic) ROI
# which gives and improved frame rate relative to searching the entirety of each frame.
#constant factors defining size of Dynamic Region of Interest (ROI)
#a is the x (widthways) factor
a = 0.33
#b is the y (lengthways) factor
b = 0.33
#calculate ROI
def roiCalc(a, b, tag, img):
img.draw_cross(tag.cx(), tag.cy(), color = (0, 255, 0))
trec = tag.rect()
#calculate ROI
ROI[0] = trec[0] - int(a * trec[2])
if ROI[0] < 0:
ROI[0] = 0
ROI[1] = trec[1] - int(b * trec[3])
if ROI[1] < 0:
ROI[1] = 0
ROI[2] = trec[2] + int(2 * a * trec[2])
if ROI[0] + ROI[2] > img.width():
ROI[2] = img.width() - ROI[0]
ROI[3] = trec[3] + int(2 * b * trec[3])
if ROI[1] + ROI[3] > img.height():
ROI[3] = img.height() - ROI[1]
#draw the ROI onto the current frame
img.draw_rectangle(ROI[0], ROI[1], ROI[2], ROI[3], color= (255, 0, 0))
return(ROI)
#initialise sensor
#initialise ROI, tag found flag and frame counter
ROI = [None, None, None, None]
found = False
i = 0
#if a tag was found in the previous frame (found == True) ...
#an ROI is defined, so search that ROI for the tag
if found:
#reset the found flag
found = False
#for an ROI a region of the image is copied in memory so memory errors
#occur, use a try except block so it doesn't stop running
#search for the tag inside the ROI defined in the previous frame
tags = img.find_apriltags(roi=ROI, families=image.TAG36H11)
except(MemoryError, OSError):
print("Memory Error")
#if a tag found inside the ROI
if len(tags) >= 1:
#tag was found so set flag to true
found = True
#parameters used to redefine the ROI based on the current tag position and size
ROI = roiCalc(a, b, tags[0], img)
#if no tags found pass
else:
#... otherwise if no tags were found in the previous frame (found == False)
#search the whole of the current frame
else:
#search for the tag in the entire frame (no roi)
tags = img.find_apriltags(families=image.TAG36H11)
if len(tags) >= 1:
found = True
#if a tag was not found then print a statement to say so
if not found:
print("Tag NOT Found")
#print the frame rate once every 10 frames
if i % 10 == 0:
print("FRAME RATE = %.2f fps" % clock.fps())
#increment frame counter
i += 1
#reset frame counter
if i > 99:
i = 0
