Turning on the camera instantly from sleep mode
gabriel_colon32
Postby gabriel_colon32 » Thu Oct 08, 2020 2:38 am
Greetings, I was wondering if it was possible for the camera to be turned on immedietly from sleep mode from the library without specifying a given repeated time. To put you in perspective, I am working on a project where rover drone must be launched from a rocket and when it lands safely, the camera must be turned on and start taking phothos.
Thanks in advance.
Re: Turning on the camera instantly from sleep mode
Postby kwagyeman » Thu Oct 08, 2020 12:36 pm
Yes, it’s possible, you need to record all relevant registers on the camera and reload them on turn on. I don’t know exactly what register settings you need to modify however.
Postby iabdalkader » Fri Oct 16, 2020 12:49 pm
You can also use extint to wake up from sleep mode:
import time, pyb, machine
from pyb import Pin, ExtInt
def callback(line):
led = pyb.LED(3)
pin = Pin("P5", Pin.IN, Pin.PULL_UP)
ext = ExtInt(pin, ExtInt.IRQ_FALLING, Pin.PULL_UP, callback)
# Enter Stop Mode. Note the IDE will disconnect.
machine.sleep()
while (True):
    led.on()
    time.sleep(100)
    led.off()
    time.sleep(100)
