uart.write doesn't write the entire buffer
GregR
Postby GregR » Thu Sep 14, 2017 12:35 am
I'm trying to write a buffer of about 60 bytes out of uart3.
It only writes between 15 and 22 bytes.
For my testing the data in the buffer doesn't change.
It's not shown here but I've used print to confirm the buffer is filled with the correct data.
Any idea of what might cause this?
uart = pyb.UART(3, 115200)
uart.init(115200, bits=8, parity=None, stop=1) # init with given parameters
def AssembleMessage(msgBody):
    dataLen = bytes([len(msgBody)-1])
    chkSum = bytes([CalcCheckSum(msgBody,len(msgBody))])
    msg = MAGIC_BYTES
    msg += dataLen
    msg += msgBody
    msg += chkSum
    bytesWritten = uart.write(msg)
    print(bytesWritten)
    #uart.write(MAGIC_BYTES)
    #uart.write(dataLen)
    #uart.write(msgBody)
    #uart.write(chkSum)
Regards,
Greg
Re: uart.write doesn't write the entire buffer
Postby kwagyeman » Thu Sep 14, 2017 1:09 am
Hi, please add:
timeout_char=1000
To the uart init call. The default call stops writing bytes after a timeout. Not sure why MP designed it this way...
GregR
Postby GregR » Thu Sep 14, 2017 4:20 pm
That did the trick! Thanks!!!!
I miss-understood the docs.
That sounded like a receive timeout.
Regards,
Greg
