Sensor snapshot takes 0.02s, can't achieve >50 FPS
Jhc999
Postby Jhc999 » Mon Nov 09, 2020 10:22 pm
This blog post suggests a default FPS of 75-150 FPS (https://openmv.io/blogs/news/more-speed). I've edited the helloworld code to time the sensor snapshot. The frame buffer on the IDE was disabled, and I have the latest firmware on my OpenMV H7 Plus (version 3.6.8).
import sensor, image, time, utime
    start = (utime.ticks_ms())/1000
    end = (utime.ticks_ms())/1000
    print("TIME", end-start)
The printed time varies between 0.20s- 0.21s. It's taking 0.2s to snap a single frame, so the maximum possible FPS is 50FPS. How do I achieve the default FPS in the blog post?
Re: Sensor snapshot takes 0.02s, can't achieve >50 FPS
Postby kwagyeman » Tue Nov 10, 2020 10:50 am
The camera frame rate is variable depending on the lighting. Please improve your lighting.
That said, we don't actually have triple buffering support yet. So, the max frame rate doesn't hold once you start processing. We will be updating the camera driver to support triple buffering in a few months.
