[SER] Connecting to COM4
[SER] Serial is connected, trying to read config…
[SER] Retrieved configuration
[SER] Device is running AT command version 1.0.0
Configuring API key in device…[WS ] Failed to set upload settings: Traceback (most recent call last):
File “”, line 1, in
SyntaxError: can’t assign to expression
[SER] Cannot connect to remote management API using daemon, failed to read apiKey, deviceId or deviceType from device. Restarting your development board might help. Retrying in 5 seconds…
I am having significant issues installing the edge impulse CLI tools. I understand this is their issue, and I have asked them for help but, suffice it to say, the edge impulse CLI install experience leaves a lot to be desired.
But, I am following your “smile” tutorial here:
Is there an updated version that does not use the Edge Impulse CLI, could you please point me to it? I am very interested in reproducing your “smile” example.
Yes, and I was almost able to complete the smile example - turns out my H7 does not have enough space to run the model from edge impulse. Oh well.
I have pre-ordered the H7 Plus and , as I also make hardware based IOT devices, I can appreciate how hard it is to make hardware now. Good luck and I look forward to getting the hardware - someday.
Thanks again for your help and good luck with this amazing product.
