hi
I have a project that requires a face mask detection with openmv and I did not find anything.
does openmv tutorial works on face mask detection ?
You can use edge impulse to do that. You have to create a data set and train a CNN.
Pretty much all the work is in collecting a dataset.
thanks kwagyeman
i run a CNN (edge impulse) with INFERENCING TIME = 167ms / PEAK MEMORY USAGE = 80kb / MODEL BINARY SIZE = 5kb on openmv m7. but fps =5 (slow)
is this normal ?How can I make it more?
167ms is about 5 FPS.
The system is an MCU, not an application professor. Reduce the model size if you want it to go faster…
