Hi, i have a Problem…
I want to install openmv ide on my new raspberry 4 (Debian Buster with Raspberry Pi Desktop Version: 02.2020).
When I execute the file setup.sh the following text appears:
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
libpng-dev : Conflicts: libpng12-dev but 1.2.54-6 is to be installed
libpng12-dev : Conflicts: libpng-dev but 1.6.36-6 is to be installed
E: Unable to correct problems, you have held broken packages.
Looking in indexes: Simple index, piwheels - Simple index
Requirement already satisfied: pyusb in /usr/local/lib/python2.7/dist-packages (1.0.2)
Could not find libts library
No the ide doesn’t work:
pi@raspberrypi:~/Downloads/openmvide/bin $ ./openmvide
./openmvide: error while loading shared libraries: libGLESv2.so: cannot open shared object file: No such file or directory
I have patched the IDE to work on a fresh Raspberry Pi 3 with the latest OS I have at home. I thought this error was fixed. Others encountered similar issues and fix their problem.
Hmm, yeah, I can assure you I’ve fixed this issue for the default RasberyPi OS image with a Pi 3. However, I’m not surprised the issue came back again… If once of these solutions works for you let me know and I’ll incorporate it into our setup.sh script.
I have the same problem than stefan broken dependencies:
Les paquets suivants contiennent des dépendances non satisfaites :
libpng-dev : Est en conflit avec: libpng12-dev mais 1.2.54-6 devra être installé
libpng12-dev : Est en conflit avec: libpng-dev mais 1.6.36-6 devra être installé
Is it an issue for this problem? (raspberry pi 4 debian buster 02/2020)
I want to install openmv ide on my raspberry 3 (Debian Buster with Raspberry Pi Desktop last Version:).
pi@raspberrypi:~/Downloads/openmvide $ python make.py
File “make.py”, line 299, in
make()
File “make.py”, line 255, in make
os.path.join(installdir, “lib/Qt/lib/fonts”))
File “/usr/lib/python2.7/shutil.py”, line 194, in copytree
names = os.listdir(src)
OSError: [Errno 2] No such file or directory: ‘/home/pi/Downloads/openmvide/dejavu-fonts/fonts/’
