WINC soft AP causes crash
frank26080115
Postby frank26080115 » Fri Aug 07, 2020 3:47 am
The following code crashes the whole board
import network, pyb
pyb.delay(1000)
wlan.start_ap("OpenMV")
when this is run, the board reboots
The line "Running in Access Point mode..." does show up in the terminal, the call to start_ap seems to crash it
I can run the code in serial terminal and it does the exact same thing
Adding delays don't help
also, setting the soft-ap parameters in the on-board settings file seems to make the board not able to connect via serial port. good thing it was easy to delete the settings file off the board, otherwise the board is kinda... I don't wanna say bricked...
Version info
MicroPython v1.12-omv OpenMV v3.6.7 2020-07-20; OPENMV4P-STM32H743
WINC firmware is Firmware version: (19, 6, 1, 19, 3, 0, 1377184)
Demo code for scanning WiFi still works
EDIT: Oh and it's important that it did work once. So maybe I need to clear the DHCP table?
EDIT: running FW update on the WiFi module did not help, still crashing
Re: WINC soft AP causes crash
Postby iabdalkader » Fri Aug 07, 2020 12:12 pm
Hi, it's seems to be a bug when using an open network (no security). I'll look into it, in the meantime if you switch to WEP it works:
import time, network, usocket
SSID ='OPENMV_AP'    # Network SSID
KEY  ='1234567890'    # Network key (must be 10 chars)
# Init wlan module in AP mode.
wlan = network.WINC(mode=network.WINC.MODE_AP)
wlan.start_ap(SSID, key=KEY, security=wlan.WEP, channel=2)
# You can block waiting for client to connect
print(wlan.wait_for_sta(100000))
print(wlan.connected_sta())
Note you shouldn't be using an open network anyway.
Postby iabdalkader » Fri Aug 07, 2020 12:51 pm
Fixed.
frank26080115
Postby frank26080115 » Fri Aug 07, 2020 5:16 pm
I noticed that wait_for_sta is pretty much useless, or a disconnected wifi client device has a really really long timeout
wait_for_sta() waits for the client to connect, I used it for testing. The same can be done with accept on a blocking socket.
Users browsing this forum: GL-ITC and 2 guests
