Trouble running two seperate if-else statement
thomasaung
Postby thomasaung » Thu Aug 06, 2020 12:07 am
import sensor, image
import pyb
from pyb import Pin
from pyb import RTC
rtc = RTC() # Real Time Clock
#Will set the clock, only need to uncomment and run once to set real time clock
#rtc.datetime((2020, 10, 8, 3, 28, 0, 0, 0))
sensor.set_pixformat(sensor.RGB565) # or sensor.GRAYSCALE
sensor.set_framesize(sensor.QVGA) # or sensor.QQVGA (or others)
sensor.skip_frames(time = 2000) # Let new settings take affect.
BLUE_LED_PIN = 3
button2 = machine.Pin('P3', machine.Pin.IN, machine.Pin.PULL_UP)
button1 = machine.Pin('P1', machine.Pin.IN, machine.Pin.PULL_UP)
valve = pyb.Pin("P0", pyb.Pin.OUT_PP)
img = sensor.snapshot
    first = button1.value() #if else statement for solenoid control
    second = button1.value()
    if first and not second:
         print('Button 1 not pressed')
         valve.value(1)
    elif not first and second:
         print('Button 1 pressed')
         valve.value(0)
    first2 = button2.value() #if else statement for camera interfacing
    second2 = button2.value()
    if first2 and not second2:
        print('Button 2 released')
    elif not first2 and second2:
         print('Button 2 pressed!')
         dt=rtc.datetime()
         dtfilename = 'spacecam_'
         for item in dt:
           dtfilename = dtfilename+str(item)
         dtfilename = dtfilename+".jpg"
         pyb.LED(BLUE_LED_PIN).on()
         sensor.snapshot().save(dtfilename)
         print(dtfilename+" saved to SD card")
         pyb.LED(BLUE_LED_PIN).off
   Hi when i run the code, only the if else statement for camera interfacing works, the statement for the solenoid control doesnt. Help will be greatly appreciated thanks!
thomasaung
Re: Trouble running two seperate if-else statement
Postby kwagyeman » Thu Aug 06, 2020 12:21 am
What behavior are you expecting? Are you trying to look for a neg/pos edge? The 1 second delays there will really make things choppy.
If the valve control isn't working I'd verify the pin works by printing the state of "first" and "second" each time in the loop.
thomasaung
Postby thomasaung » Thu Aug 06, 2020 12:56 am
The behaviour im expecting is that when i press a respective button, for eg button1, i only want the if else statement of button1 to run.
Postby kwagyeman » Thu Aug 06, 2020 2:22 pm
Can you give me the print output I requested? I don't see a bug for starting at your code. So, Im thinking is a hardware/mechanical issue.
thomasaung
Postby thomasaung » Fri Aug 07, 2020 12:18 am
im looking for a negative edge, from high to low, i will post my individual if elsif loops.
thomasaung
import pyb
from pyb import Pin
    time.sleep(2)
        print('Solenoid valve closed')
        valve.value(1)
        print('Solenoid valve open')
        valve.value(0)
Postby kwagyeman » Fri Aug 07, 2020 1:31 am
Please post the print output of you testing it. As I said, it doesn't look wrong.
