Attached is error I am getting. Need help.
Getting OSError: The pathname format is invalid
Adding more info
OpenMV 10E 2.4.0
OpenMV H7 R1
WiFI ATWINC1500-MR210PB
Adding more info
OpenMV 10E 2.4.0
OpenMV H7 R1
The firmware file should be on SD card, please undo the changes to the path read the comments in the script.
Thanks, fixed it. I am connected now.
I have another questions
Hi, wifi gives you low level socket control. You can do anything with sockets. If you need an example of how to write this code see our rtsp driver: openmv/rtsp.py at master · openmv/openmv · GitHub
See the web servers example in the ide for using the above library.
Thanks for the prompt reply.
I am reviewing and it says on supports OV2640/OV5640
I have OV7725, what changes do I need to make?
You don’t need to make any changes. However, VLC will not playback the jpeg images we produce with software jpeg compression. Other rtsp programs may work. This is more of an issue with VLC than the OpenMV Cam.
