use as a contrast sensor
rajeshktym
Contact:
Postby rajeshktym » Tue Nov 12, 2019 2:05 am
In my project, i am trying to use H7 sensor work like a contrast sensor, means i can minimise the capture area to set sensor.set_windowing((40, 10)) to detect black mark from rotating roller with in 1 milli second. image processing may took more time if any another function can use to achieve the result (black / white frame detection).
Thanks in advance
Re: use as a contrast sensor
Postby kwagyeman » Tue Nov 12, 2019 2:42 am
Use get_stats() or get_histogram().
rajeshktym
Contact:
Postby rajeshktym » Wed Nov 13, 2019 12:50 am
import sensor, image, time
sensor.set_framesize(sensor.QQQVGA)
sensor.set_windowing((60, 10))      # Set frame size to QVGA (320x240)
sensor.ioctl(sensor.IOCTL_SET_TRIGGERED_MODE, True)
    clock.tick()                    # Update the FPS clock.
    dd = img.get_stats().mean()
    #dd = img.get_histogram()
    #print(dd)
    if dd < 100:
        print("FPS:%d > %s"% (clock.fps(),dd))              # Note: OpenMV Cam runs about half as fast when connected
Hi Iwas trying to use above code for detect black frame with global shutter trigger mode, but it still detect black in very low FPS, with this approach can we get black or white detection with in 100-200 micro seconds?
Postby kwagyeman » Wed Nov 13, 2019 1:58 am
You have to set the camera exposure to be a low value. See the Global Shutter example high FPS script.
That said, 100-200 microseconds isn't happening except on an FPGA... That's obscenely fast. You can get 400 FPS max. 100-200 microsecond is much faster than that. I do not know where you are getting this 100-200 microsecond number from.
rajeshktym
Contact:
Postby rajeshktym » Wed Nov 13, 2019 2:12 am
Hi kwagyeman
I m capturing this black mark from moving conveyer which run in speed of 100 - 250 meter per minute (4000 mm /sec) means with in 250 micro second 1 mm mark will be move from sensor,
Postby kwagyeman » Wed Nov 13, 2019 11:13 am
Understood, but, even if you set the resolution to be 80x60 and the exposure to be very low to get the 400fps rate this doesn't get you up to 100 microseconds... You need a 10k fps camera to hit that.
Can you send an image of the problem? Maybe it's possible to lower the frame rate.
rajeshktym
Contact:
Postby rajeshktym » Thu Nov 14, 2019 12:10 am
Hi
I m planning to use TSL1401CL 128X1 Linear CCD Camera Sensor, which can read 128 pixel data with 38 micro seconds. I hv realised openmv will not meet my this requirement,
Postby kwagyeman » Thu Nov 14, 2019 3:09 pm
Yeah, that kind of sensor would be more suited to your task.
