nn_quantizer.py for CIFAR10 got error blob_dims == blob->shape() Cannot load blob from hdf5
I have download code from git clone GitHub - ARM-software/ML-examples: Arm Machine Learning tutorials and examples
I have executed ML-examples ->cmsisnn-cifar10 and successfully generate mean file mean.binaryproto,cifar10_test_lmdb and cifar10_train_lmdb.
through below command
cd $CAFFE_ROOT
./data/cifar10/get_cifar10.sh
./examples/cifar10/create_cifar10.sh
While converting trained Caffe model into .pkl file, so that it can be converted to cmsis-nn source file, by below command.
python nn_quantizer.py --model models/cifar10_m7_train_test.prototxt --weights models/cifar10_m7_iter_300000.caffemodel.h5 --save models/cifar10_m7.pkl
got below error
**Check failed: blob_dims == blob->shape() Cannot load blob from hdf5;
shape mismatch. Source shape is 16 32 5 5 (12800) target shape is 32 32 5 5 (25600)
*** Check failure stack trace: *****
I don’t know why the above error occurs as I am using a trained Caffe model without any modification for reference I have attached prototxt file. I am new to Caffe, please help me.
cifar10_m7_train_test_prototxt.txt (2.75 KB)
Did you follow the instructions here:
https://github.com/openmv/openmv/blob/master/ml/cmsisnn/README.md
Also, I’m porting TensorFlow again. We will have it done by the end of the week. This gets us off caffe finally.
I did not train the model, just try to convert it into .pkl file.
run below script without GPU, is it ok
