Reducing the number of GRAYSCALE levels (8 bits to 3 bits)
Jivrik
Postby Jivrik » Thu Mar 28, 2019 9:19 pm
I am trying to reduce the grayscale level on the openMV frame. Instead of having a range of grayscale going from 0 to 255, I want a level of grayscale going from 0 to 7.
Is it possible?
If yes, How can i do it ?
Re: Reducing the number of GRAYSCALE levels (8 bits to 3 bits)
Postby kwagyeman » Thu Mar 28, 2019 11:24 pm
Hi, download the latest firmware and use the gamma_corr() method and set the contrast adjustment to be 0.03125.
https://github.com/openmv/openmv/blob/m ... rection.py
Jivrik
Postby Jivrik » Fri Apr 12, 2019 8:15 pm
Thank you.
I got confused when trying to update the firmware.
Do I have to load a .dfu file from Tools > run bootloader?
Postby kwagyeman » Fri Apr 12, 2019 8:17 pm
Hi just use the firmware.bin file in the OPENMV3 folder for the M7. The H7 is the OPENMV 4 folder.
Jivrik
Postby Jivrik » Fri Apr 12, 2019 8:48 pm
Please ,
How do you get the numbers for the gamma correction?
What is the maximum value of the contrast and the brightness?
Also I tried to print the pixels values collected using the operation below:
img = sensor.snapshot().gamma_corr(gamma = 0.03125, contrast = 1.0, brightness = 0.0)
I keep having values between 0 and 255 ; and not 0 and 8 since I should have a 3 bits grayscale.
Jivrik
Postby Jivrik » Wed Apr 17, 2019 7:12 pm
Just in case you missed this question.. Could you please help me out with this as well?
Thanks.
Postby kwagyeman » Thu Apr 18, 2019 1:46 am
Yeah... so, you want to pass the 0.03125 value to contrast, not gamma. The values are passed to every pixel channel normalized to 1. E.g. a brightness of 1 makes the whole image white and maxes everything out. Contrast of 2 multiplies all pixels by 2. Gamma is different and does the standard image gamma operation.
