Hi, just received my OpenMV cam and looking forward to getting to see what it can do. I have downloaded the installer “openmv_win32_AMD64_v1.4.zip” from the Download section where it says “For Windows XP, Vista, 7, 8, or later”. I then unzipped to root directory "C:" using IZArc and execute “openmv-ide.exe” after which “avast” kicks in and does a scan of exe. After this a message pops up “The application has failed to start because the application configuration is incorrect. Reinstalling the application may fix this problem”. Has anyone enountered this - any ideas on what is going wrong here ? Not too sure where it is pulling the configuration from.
Simply deleting the file “openmv-ide.exe.manifest” or renaming solves the problem ![]()
Once I get done with the tutorial I am definitely going full-time to fix the IDE…
